A little finish repair help needed
Forum topic by Shopsmithtom posted 1484 days ago 613 views 0 times favorited 6 replies Add to Favorites Watch
View Shopsmithtom's profile
Shopsmithtom
768 posts in 2366 days
1484 days ago
Topic tags/keywords: finish repair question
I thought the finish on my oak computer desk (that I did not build) was polyurethane & not subject to that foggy whitish moisture mark, but after putting a pizza on it’s cardboard plate on the desk after it came out of the oven, I realized that it was a bad idea. The warmth & moisture condensation caused the old white (pizza shaped) mark.
Although I remember reading somewhere how to deal with it, It escapes me now that I have a problem. I’m looking for a way to get the white out without having to re-finish the desk. The finish has not picked up, just gotten cloudy. Can anybody help? Thanks. -SST
-- Accuracy is not in your power tool, it's in you
Douglas Bordner
3907 posts in 2235 days
#1 posted 1484 days ago
While I haven’t used this product, I gave had luck with other Liberon products. I too remember a tip posted here, but I can’t recall it now.
Anybody else remember?
View tenontim's profile
tenontim
2129 posts in 1915 days
#2 posted 1484 days ago
I’m not a big poly fan, but I’ve been told that you can warm poly and rub it into the old finish and it will repair any damaged spots. This is if you have poly on the desk. Might be worth a try.
-- Tim-- http://www.tmuli.com
View Sam Yerardi's profile
Sam Yerardi
244 posts in 2066 days
#3 posted 1483 days ago
The white ring you are seeing is caused by moisture, typically in the outer-most portion of the finish. Whether or not you have a high gloss finish will determine how you need to fix it. There are a couple of things you can try. The first, the easiest, but CAUTIOUSLY, use a hair-drier on the lowest setting and warm the spot up a bit, but NOT ENOUGH TO CAUSE THE FINISH TO BUBBLE. Very slight warmth for a short period of time will help the moisture migrate out of the finish. Another approach, if it was caused by alcohol, is to use a few drops of ammonia on a damp cloth. Both of these methods are intended for surfaces that are not high gloss.
A high gloss finish may require addressing the entire finished surface.
Hope this helps.
-- Sam
87268 posts in 1748 days
#4 posted 1466 days ago
Sam has a good approach one old approach is to rub some mayonnaise on the circle sometimes the oil in the mayonnaise will help get rid of the ring.
View Durnik150's profile
Durnik150
647 posts in 1493 days
#5 posted 1466 days ago
Hmmmmm, I learn something new every day here! Honey, bring the Mayo!!
-- Behind the Bark is a lot of Heartwood----Charles, Centennial, CO
View Greg The Cajun Box Sculptor's profile
3779 posts in 1479 days
#6 posted 1466 days ago
Mayonnaise on pizza?
-- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com
