How to use white diamond rouge
« back to Hand Tools forum
Forum topic by Sanderguy777 posted 02-13-2015 02:19 AM 1291 views 0 times favorited 4 replies Add to Favorites Watch
View Sanderguy777's profile
Sanderguy777
179 posts in 1322 days
02-13-2015 02:19 AM
Topic tags/keywords: rouge white diamond polisher polishing wheel polishing compound trick tip question carving tool blade finishing sharpening
I have some white diamond rouge but, I have no idea of the right way to use it. It chips and makes a bunch of dust when I use it dry on my home made polisher. Is there some trick or some liquid I have to use? I am using a polishing wheel but I’m not sure what kind. ( I moved into the house and the polisher and compound came with it) Thanks
P.S. I am wanting to use it on metal (knives, tools, etc)
-- Marc Spagnuolo (standing in front of clamp wall): I think I need a few more . Me (owner of at least 8 clamps):.....?
View ElChe's profile
ElChe
630 posts in 1456 days
#1 posted 02-16-2015 01:38 AM
On a wheel you only need a little bit to charge the wheel. I am assuming this is in the form of a bar or rectangular block. Not all wheels work well with white diamond compound. I dress the wheel first with end grain wood to remove used up prior compound and lightly apply the bar to spinning wheel for a couple of seconds with light pressure. Then I go at it. It does tend to create a sticky dust especially if you over charge the wheel. I don’t use white diamond on a strop. I prefer the green compound on an MDF strop.
View timbertailor's profile
timbertailor
1594 posts in 1544 days
#2 posted 02-16-2015 02:33 AM
I will cut a small piece and crush it up with a drop of water or two to make a thick paste. The heat will soon evaporate the excess moisture. Its messy, no doubt about that, so use a cardboard box or some other containment structure to reduce the mess.
I use it with a hand held die grinder and the cheap HF kits for polishing aluminium.
Sanderguy777
#3 posted 02-16-2015 02:39 AM
The stuff I’m using is in bar form and is quite old (it is flaky) I use it for polishing metal, but not sharpening.
timbertailor
#4 posted 02-17-2015 07:19 PM
The stuff I m using is in bar form and is quite old (it is flaky) I use it for polishing metal, but not sharpening.
- Sanderguy777
+1
White diamond is for fine polishing.
Even a black emory is probably too fine for sharpening.
