Need help Cutting Malamine for track runners
Forum topic by Jake posted 04-30-2009 08:26 PM 982 views 0 times favorited 6 replies Add to Favorites Watch
View Jake's profile
Jake
44 posts in 3235 days
04-30-2009 08:26 PM
What’s the best way to cut track runners on the top surface of Malamine? Should I use a router or Dado blade and should I tape off the area to reduce chipping? Thanks.
-- Jake, Papillion, Nebraska
View rickf16's profile
rickf16
390 posts in 3487 days
#1 posted 04-30-2009 09:10 PM
A good dado blade and blue painters tape. Also, you might want to try scoring the cut line with a utility knife before cutting. Good luck
-- Rick
View Jake's profile
Jake
#2 posted 05-01-2009 12:16 AM
Thanks for the info. I will give it my best shot.
View CoolDavion's profile
CoolDavion
433 posts in 3731 days
#3 posted 05-02-2009 04:41 AM
I had used a router for my router table, there was a some chiping. If you use a router, don’t go too deep in a pass.
-- Do or do not, there is no try!
35099 posts in 4307 days
#4 posted 05-02-2009 04:52 AM
I go with Barry. Use a negative angle saw blade. They are made for that purpose.
View Jake's profile
Jake
#5 posted 05-03-2009 05:10 AM
I think I will try the negative angle blade. Thanks again.
116906 posts in 3483 days
#6 posted 05-03-2009 05:11 AM
Good luck may the chip be with out you. ....weird
