Want to buy Motor from Harbor Freight Lathe
Forum topic by Thuzmund posted 02-13-2015 01:56 AM 972 views 0 times favorited 3 replies Add to Favorites Watch
View Thuzmund's profile
Thuzmund
151 posts in 1866 days
02-13-2015 01:56 AM
Hi folks,
If anyone has a working motor from the Harbor Freight 34706 12×33 lathe, let’s make a deal. Mine has a problem and I’d like an exact replacement. If you have upgraded or don’t care for the unit, let me know please!
Thanks
-- Here to learn
3 replies so far
MrUnix
7106 posts in 2436 days
#1 posted 02-13-2015 02:13 AM
Those motors are notoriously bad.. what is the problem you are experiencing? From what I can gather, it’s a 1700RPM thing with a 5/8” shaft and a groove on the end for a circlip. I’ve seem where some people have gotten so fed up with replacing the motor (under warranty, multiple times) that they swapped it out with a DC motor like that from a treadmill.
Thuzmund
#2 posted 02-13-2015 02:31 AM
The motor was fine. I was wiring a reverse switch into it, but since it’s totally-enclosed, I had to drill a hole in the housing to run wires out for the switch. And of course I slipped and ate up a couple of the windings with my drill bit!
The shaft is a common size (16mm) but very long with two grooves for circlips and a long key as well. On top of that, the motor is mounted via the motor end cap itself, and two motors I have are just a hair too big to accept the end cap. There’s just so many unique aspects that I know it won’t be worth it to track down a replacement.
Since everyone hates the dang thing, I figure someone will want to make a deal. :)
-- Here to learn
View TRHeath's profile
TRHeath
75 posts in 1825 days
#3 posted 02-26-2015 10:22 PM
I replaced the one on that same lathe with a direct replacement ordered from HF. Less than $100 to my door if I remember correctly.
-- So much to learn....so little time.....
