Making a fence for table saw and bad bearing ???
Forum topic by MNbuzzdust posted 211 days ago 247 views 0 times favorited 9 replies Add to Favorites Watch
View MNbuzzdust's profile
MNbuzzdust
99 posts in 249 days
211 days ago
1. I have seen people make fences for their table saws but not sure where they get or make the strips that slide into the slots there your miters slides??
2. I may have a bad bearing on my delta table saw as I can hear some rattling on start up. Can these be replaced or the motors be replaced???
Thanks
View milehigh's profile
milehigh
47 posts in 237 days
211 days ago
I replaced the bearing in an old 1948 Craftsman saw that was on the arbor of the saw. Noticed it was bad while trying to tune up the saw. I could get the blade in line with the miter slot until i put the belt back on. Then it would be way out. See if you can track down the exact source of the noise before you start tearing things apart. It was easy to replace the bearing. Getting to it was another matter.
Paul
View Skarp's profile
Skarp
180 posts in 223 days
211 days ago
Are you talking about a crosscut sled? Most people I’ve seen make their own just rip a piece off a board that is the same thickness as the width of the miter slot. I can’t think of a rip-fence that would use miter gauge slot inserts.
Pretty much any Delta or major brand table saw can have all parts replaced if the thing is not an antique, and even then sometimes.
-- Ooo, er.
MNbuzzdust
211 days ago
Yes the sled is what I meant thanks for clearing that up! I was thinking maybe a guy could buy some of that material that fits exactly in the slot somewhere. I guess Ill just use wood. Thanks
View marcb's profile
marcb
704 posts in 571 days
211 days ago
Arbor bearings and motor bearings are pretty easy to replace. If you don’t feel comfortable doing it pretty much any machine shop can probably press the old ones off and the new ones on for a minimal charge.
Skarp
211 days ago
I think you CAN buy the runners, but a little bit of scrap wood probably costs a lot less. I used a bit of cypress for mine, maybe 10 cents worth. Been working just fine for a couple years. I might make another one with more features here sometime though. Brass threaded inserts and t-track for hold downs so I can do really small pieces. Saw some video of a wooden puzzlemaker’s setup a while back. Really neat sled he has. I’ll try to find a link.
-- Ooo, er.
TopamaxSurvivor
3048 posts in 573 days
211 days ago
All the wookworking specialty stores have poly material in lots of sizes. A 3/4” thick x 4 ’ x about 4” will be in the $20 range, I think. Most TS sots are 3/4” I believe.
View brianinpa's profile
brianinpa
1365 posts in 620 days
211 days ago
I work on a bargin basement budget, so when I made my cross cut sled I made my own strips out of oak scraps. You only need to make it a hair smaller than the slot.
Bearings are easy to replace. You will find it easiest to remove the motor end from the motor nad the bearings should come just fall out of the end caps.
Skarp
211 days ago
Ok. just posted the video link as a personal blog entry, didn’t want anyone to miss it buried in a thread. Too good to miss.
-- Ooo, er.
MNbuzzdust
211 days ago
Skarp
That is an awesome sled and that guy must have some serious patience to design and build those puzzles!
I think Ill just be making a basic sled for now but the possibilities are endless.
Brian thanks for the bearing info Ill dig into it.
