| Forum topic by Barto | posted 212 days ago | 456 views | 0 times favorited | 9 replies | ![]() |
212 days ago |
Topic tags/keywords: tools bandsaw Hi, Just a quick q’ from a newbie… Can you use a metal band saw for wood working? Like the one on trademe (New Zealand’s own eBay): Metal band saw Thanks! -- Bart, Waimauku NZ |
212 days ago |
Well, with a blade designed for cutting wood, technically yes. However I wouldn’t want to, as they are designed with different goals in mind and if the saw was used for metal cutting then you’d be dealing with metal shavings and oil and such getting on the wood. I’d really look for a woodworking band saw with a nice table, miter slot and fence. Also not sure if they make wood blades for any given size of metal saw. -- Ooo, er. |
212 days ago |
Skarp is right about the blade but also the saw you referenced is strictly for cutting something to length. You would be missing out on some of the real advantages of a “regular” band saw such as resawing, cutting curves etc. |
212 days ago |
like lew said – horizontal metal cutting bandsaws are designed to cross-cut metal pipes to length, whereas the real strength of a woodworking bandsaw is it’s ability to rip to width… like when resawing, or ripping rough lumber safely. more things that a woodworking bandsaw (vertical) incorporates are the fact that there is a table perpendicular to the blade which allows intricate cuts – curves, joinery, etc. so, to answer you question – no, this type of metal bandsaw wouldn’t work for woodworking. -- When in doubt - There is no doubt - Go the safer route. |
212 days ago |
The price is right but the machine is wrong for woodworking. In its present form, it’s designed only to cut a straight line in metal and very slowly using liquid to wash the swarf. You have to get rid of the liquid flow, speed up the drop to a much faster rate and then…maybe. But you can cut straight lines in wood already and faster and more accurately with other much more versatile tools like a table saw or even a jigsaw. yes, you could use it to cut wood, but its use would be very limited. If you can take it apart, sit it upright and add a table, change the blade to a wood cutting blade ( plenty of shops here will weld up a custom length blade – topmaq for example ) then you might have a tool worth using for woodworking. Personally, I’d pass on it and look for a woodworking ( or even something like a butcher’s bandsaw) model which has all those features already. -- Steve, New Zealand, www.steveracz.com |
212 days ago |
a wood working bandsaw is worth its weight in gold when ripping rough lumber like Purplev mentioned. Makes it dead easy to use wide boards to make small parts with out all the jointing or fear of kick back. I pent about 4 hours this week doing just that, last project I used rough lumber on I didn’t have the bandsaw, it has now paid for itself not even mentioning all the resaw and curve work I’ve used it for. |
211 days ago |
Cool, thanks! makes sense -- Bart, Waimauku NZ |
181 days ago |
Sorry for adding to this so late…. -- The woods are lovely, dark and deep, but I have promises to keep... |
177 days ago |
The big gap between the teeth on a bandsaw blade is essential for clearing sawdust out of the curve as it cuts, In general wider gaps (less teeth per inch) are better for most uses including re-sawing. Finer toothed blades are useful for doing scroll type work or other work where you need a fine cut and/or it would be difficult to sand -- Mike, American in Norway |
177 days ago |
Listened to all the advise! Couldn’t really come up with an excuse to spend NZ$800+ on a tool I’ve never used before so bought a ‘desktop’ model on trademe (NZ’s eBay) for $65 (about 40 US) – and I love it! Will probably replace it with something more serious at some stage. Understand what you’re saying Stefang! The small bandsaw I bought is excellent for scrolling, resawing was less successfull! -- Bart, Waimauku NZ |
| Forum | Topics |
Woodworking Skill Share
2921 |
3949 |
257 |
950 |
225 |
Woodworking Trade & Swap
620 |
Coffee Lounge
2394 |
LumberJocks.com Site Feedback
524 |
