Foot Switches
Forum topic by Adon posted 04-29-2009 06:37 PM 1270 views 0 times favorited 12 replies Add to Favorites Watch
View Adon's profile
Adon
9 posts in 3339 days
04-29-2009 06:37 PM
Just wondering if anyone uses these? And what machine(s) you’re using it on? We’ve got one on our drum sander, and it’s saved me more than once.
I’m just wondering what other machines we might want to put one on.
-- http://www.industrialshapeandform.com
12 replies so far
View oldskoolmodder's profile
oldskoolmodder
801 posts in 3705 days
#1 posted 04-29-2009 07:08 PM
I occasionally use one with my Hitatchi Table Saw, The Craftsman one, never. The problem is, you have to remember to turn off the switch on the saw, in case you accidentally step on the switch. The Switch itself helps when I need to cut a rather large piece of Plywood, or whatever. Just put the switch where I need to start and maneuver the wood to the blade, then step on the switch. Ready to go.
View PurpLev's profile
PurpLev
8536 posts in 3674 days
#2 posted 04-29-2009 07:10 PM
router table
View Kindlingmaker's profile
Kindlingmaker
2656 posts in 3551 days
#3 posted 04-29-2009 07:12 PM
Only used on the scroll saw, excellant. I don’t feel it’s a safe thing to use anywhere else. Well, maybe the dust collector but I have not tried that one yet. Just my veiw…
3809 posts in 4047 days
#4 posted 04-29-2009 08:45 PM
Router, drill press, thickness sander.
View Durnik150's profile
Durnik150
647 posts in 3347 days
#5 posted 05-03-2009 11:54 AM
I used one on my Dusto Collection system for a while. It went kaplooey after about 3 months. I ended up replacing it with a remote control version. It worked just fine for that application.
Some folks use a variable speed version with their scroll saws. I don’t scroll so hopefully someone else can help with that side.
-- Behind the Bark is a lot of Heartwood----Charles, Centennial, CO
View Steelmum's profile
Steelmum
355 posts in 3988 days
#6 posted 05-03-2009 01:24 PM
Scroll saw. Along with a swivel shop chair. Excellent!
-- Berta in NC
117115 posts in 3602 days
#7 posted 05-04-2009 01:30 AM
cordless drill LOL .I use one on my table mounted biscuit joiner by delta.
View jeffthewoodwacker's profile
jeffthewoodwacker
603 posts in 3829 days
#8 posted 05-04-2009 01:41 AM
I use one for the scroll saw.
-- Those that say it can't be done should not interrupt those who are doing it.
View Pete_Jud's profile
Pete_Jud
424 posts in 3778 days
#9 posted 05-04-2009 01:51 AM
I will be using one tonight for one of the routers on the dovetail jigs. Use it all the time on the router tables, and on the drill press. Thanks for reminding me, need to order a second one.
-- Life is to short to own an ugly boat.
View whitedog's profile
whitedog
652 posts in 3482 days
#10 posted 05-04-2009 02:30 AM
cordless drill … that was funny
-- Paul , Calfornia
View mjasper's profile
mjasper
14 posts in 3272 days
#11 posted 07-06-2009 12:41 AM
Durnik150 has a good point about the switch failing. I personally only use one regularly on my scroll saw, and one reason for that is the switch has a maximum load that is less than most other stationary machines in the shop. Of course, every switch differs, but that’s just my experience. I occasionally use it on my Dremel rotary tool though, and it works great for this application due to the awkward placement of the switch on the tool.
View John Gray's profile
John Gray
2370 posts in 3910 days
#12 posted 07-06-2009 12:50 AM
Scroll saw, the small band saw, and Work Sharp WS3000.
