Tools (humorous)
« back to Coffee Lounge forum
Forum topic by Don Newton posted 215 days ago 471 views 2 times favorited 17 replies Add to Favorites Watch
View Don Newton's profile
Don Newton
533 posts in 518 days
215 days ago
Topic tags/keywords: funny tools
Subject: Tools
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, ‘Oh [bleep]!’
SKIL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand. Other uses may include launching nuts and bolts at a very high rate of speed when said items are squeezed too hard.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood Projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used To convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
SON OF A BITCH TOOL: Any handy tool that you grab and throw across the garage while yelling ‘Son of a bitch!’ at the top of your lungs. It is also, most often, the next tool that you will need.
-- Don, Pittsburgh
View Don K.'s profile
Don K.
1095 posts in 226 days
215 days ago
I laughed my butt off at some of those !!!! ALL to true.
-- Don S.E. OK
View Bret's profile
Bret
90 posts in 394 days
215 days ago
Hysterical. Thanks for the laugh!
-- Bret, Colorado
25873 posts in 1300 days
215 days ago
Great laugh. But too true to be really funny.
View HokieMojo's profile
HokieMojo
1142 posts in 627 days
215 days ago
its funny when it has happened to you in the past. It’s not funny when you know it is going to happen to you in the near future.
View Joe Weaver's profile
Joe Weaver
109 posts in 586 days
215 days ago
way too true
-- Joe, Ga
Beginningwoodworker
4233 posts in 572 days
213 days ago
Hum yes its truth.
-- CJIII Future cabinetmaker
View steveosshop's profile
steveosshop
208 posts in 525 days
213 days ago
This is too funny.
-- Steve-o
View PirateOfCatan's profile
PirateOfCatan
53 posts in 299 days
213 days ago
I kept getting a mental picture of ONE project in progress with new things going wrong as you use a new tool.
-- P.O.C.
View DAN 's profile
DAN
6464 posts in 882 days
203 days ago
View DAN 's profile
DAN
200 days ago
View stefang's profile
stefang
1656 posts in 234 days
200 days ago
Thank you thank you Don. It’s been awhile since I’ve laughed so much. it just proves that humor is based on real life situations, since I have probably been involved in most of the described scenarios in one way or another. If I hadn’t looked at some of your stuff I would have suggested you should work at comedy full time. Do you?
-- Mike, American in Norway
View DAN 's profile
DAN
197 days ago
When Felix, the regional sales manager for a machine tools company, got home from the office, his wife couldn’t help noticing that his tie was loose, his fly unzipped, his hair dishevelled, he smelled of perfume, and his collar was covered with lipstick.
“Rough day at the office” she commented.
“Not too bad,” he said nonchalantly. “Had to break in a new sales associate, but I think she’ll work out.”
“Does she take shorthand” asked his wife.
“No,” blurted Felix, “but she gives it.”
Don Newton
195 days ago
Thanks all, I’m glad you enjoyed the post. It did not originate with me, I only passed it on.
Mike, Thanks but I am not a comedian, just a woodworker who poses as one!
Dan, Whew…..where did that come from?
-- Don, Pittsburgh
View DAN 's profile
DAN
194 days ago
View DAN 's profile
DAN
188 days ago
View DAN 's profile
DAN
175 days ago
View DAN 's profile
DAN
168 days ago
