Forum topic by RRGR | posted 04-28-2009 06:06 PM | 888 views | 0 times favorited | 2 replies | ![]() |
This is a question of technique. I was looking to make sled for mitered cuts at 45’. I thought it would be difficult to get the blade into the slot at the right level with the blade tilted at the table. I was going to need the built in zero clearance blade tolerance of a sled because of small parts of boxes that I plan to produce. Would it be more accurate to set the board at 45’ and keep the blade upright. This would eliminate any problem with too much clearance around the blade. |
