1-part epoxy vs. 2-part epoxy for the shop floor
Forum topic by mziem posted 210 days ago 1352 views 0 times favorited 21 replies Add to Favorites Watch
View mziem's profile
mziem
20 posts in 211 days
210 days ago
Topic tags/keywords: question shop
This is my first post so I hope I get it right. I FINALLY have a dedicated shop all my own and I want to put an epoxy floor covering down. I went to the BORG and they have 2-part epoxy in a kit ($72) and 1-part epoxy in the 1 gallon can ($27).
1) What’s the difference between the 1-part and 2-part?
2) Which one should I use for my concrete shop floor?
-- We are what we repeatedly do. Excellance, therefore, is not an act but a habit. ~Aristotle~
View lilliputianfrivolity's profile
6 posts in 234 days
210 days ago
one part won’t necessarily hold as well as two part
also – 2 part epoxies you can handle separately, until whenever you want you can combine the together after they have been applied.
now as far as the flooring?? tell me more about this. are you using one of those concrete in a can from the depot or do you have tiling. if it is tiling, find out what material it is made of.
you know what- heres what ill tell you,
what can the2 part do that the 1 part cannot? and also 2 part epoxies are always better in most circumstances
you know you want that expensive 2 part right? will the 1 part get the job done?
View Sawdust2's profile
Sawdust2
1185 posts in 982 days
210 days ago
I can not tell you what the difference is.
I used the 2 part on both my shop and my garage.
On a par with a dust collector as the best thing I have ever put in my shop.
Works exceedingly well at helping to keep the floor clean.
You must make sure that you entirely cover the floor on the first application. If you have a little left over and see that you missed a spot if you try to cover that the next day it will not match colorwise, although it will still cover the floor.
I do not remember which brands I used but I got one at HD (shop) and the other (garage) at Lowes. The Lowes was easier to mix because of the way it was packaged. The “mixing bowl” was sized to fit a roller, not just a round can. Price was just about the same.
If you have fiberglass mixed in your cement you can not use epoxy covering. A friend found that out the hard way.
I got about 400 sq ft per kit.
Consider it like a tool. Buy the best that you can afford at the time otherwise you will be dissatisfied.
My $.03
View depictureboy's profile
depictureboy
306 posts in 537 days
210 days ago
im curious why you cant use the epoxy on fg impregnated concrete? I would think the epoxy would be excellent for that since its basically the same thing as covering fiberglass on a kayak hull with 2 part epoxy…unless its not really epoxy and something else….but you can use polyester resin to do the same thing on a kayak…so I dont get it.
-- If you can't build it, code it. If you can't code it, build it. But always ALWAYS take a picture.
View interpim's profile
interpim
446 posts in 353 days
210 days ago
I would assume the epoxy would break down the fiberglass.
-- San Diego, CA US Navy
mziem
210 days ago
Y’all are awesome! Thanks for the advise.
lilliputianfrivolity: As for your question about about my floor, It is a poured foundation concrete floor. I had the home builder make the shop when we had our house built. It’s actually a detached “2-car garage” but, I refuse to refer to it as that. It’s like calling a Ferrari your “car”.
Mike
View dustmaker's profile
dustmaker
33 posts in 342 days
210 days ago
I used the 1-part in my shop five years ago and it has held up very well. I used a Behr epoxy coating.
-- Dustmaker, Kansas
View DaveH's profile
DaveH
372 posts in 673 days
210 days ago
I used 2 part and can’t be happier. I’ll never own another garage without finishing the floor.
I had fiberglass added to my concrete on my last shop (it’s a waste of money, by the way) and had to run the sander over it to knock down the fibers that came through the surface before I applied the 2 part finish. No problems.
-- DaveH - Boise, Idaho - “How hard can it be? It's only wood!”
25801 posts in 1295 days
210 days ago
I used the one part in my bathroom in the shop and it seems to be working out all right.
But it doesn’t get heavy use. I just wanted something that I could mop easiely.
View sIKE's profile
sIKE
1094 posts in 648 days
210 days ago
Most importantly is that your floor be absolutely clean. Put it this way. Work on cleaning the floor very well. Your done right? No. Consider it absolutely filthy and start again. Do this as many times as you can stomach. The cleaner the concrete the better it will adhere. From my reading and experience the two part epoxies have better adhesive qualities…
depictureboy
209 days ago
interpim…that cant be right…2 part epoxy and fiberglass are a staple in making strip boats…
View PurpLev's profile
PurpLev
2752 posts in 543 days
209 days ago
it’s been some years ago, but I used to fix my surfboard with 2 parts epoxy , and it’s made of layers of fiberglass.
I also build some hardshells (for mounting video cameras on helmets) made of layers of fiberglass, and 2 parts epoxy between each layer. definitely does not melt the fiberglass..
unless the epoxy used for flooring has additional ingredients in it?
View Doug S.'s profile
Doug S.
306 posts in 602 days
208 days ago
Whatever you get, the color willl make a HUGE difference in the overall brightness or darikness in your shop. I dont have the best liighting so went with a white 2-part (Shield Crete). It really increased the overall brightness in the shop without making any changes to the liighting.
-- Use the fence Luke
View eddy's profile
eddy
284 posts in 259 days
207 days ago
I used 1 part behr on the floor of my shop i have pix’s on my home page if you go with the 1 part you can have it tinted any color you want
View JimmyNate's profile
JimmyNate
44 posts in 245 days
207 days ago
I used a concrete sealer followed by concrete paint and it worked great and was far cheaper than a 2 part epoxy system.
-- "We are what we repeatedly do; excellence then is not an act but a habit." ---Aristotle
View Woodchuck1957's profile
Woodchuck1957
950 posts in 658 days
207 days ago
This reminds me of an idiot I use to worked for, he is one of those profit off of everyone elses labor while he’s the know it all slave driver. He and his crew went to a Ingersol-Rand manufacturing plant to coat a break room floor with two part Epoxy. They rolled on the first part, then rolled on the second part. Needless to say, the floor never dried and they had to wipe it all off, I doubt he had respirators for his workers. I heard the story from a friend of mine thats a painter, the story was confirmed by an employee at IR. I don’t know how the guy makes a liveing, alot of decisions were poor, it’s the reason I left.
depictureboy
207 days ago
why didnt the floor dry woodchuck…where was the breakdown in the process?
PurpLev
207 days ago
2 part epoxy needs to be mixed properly (the 2 parts) in a bucket/container prior to rolling it on the floor… you don’t just roll 1 part, and then roll the other… it won’t mix, and the hardener won’t affect the resin which will stay wet
View RedShirt013's profile
RedShirt013
116 posts in 556 days
207 days ago
I have also read somehwere that if you are using expoxy floor coating in a garage, find the area where your car tires roll over repeatedly where you park before, and rough up the concrete floor with a belt sander. This is before and in addition to the acid concrete etcher that you need to use before applying the epoxy paint itself.
On the topic of drying, make sure you check the weather report to make sure the few days after you apply there’s no cold spell. I believe the stuff doesn’t catalyze and cure to full strength if it’s below 10 degree celsius
-- Ed
depictureboy
207 days ago
Thanks purplev…I didnt get that from woodchucks story…I was thinking coats, not resin and hardener…
TopamaxSurvivor
3017 posts in 570 days
206 days ago
Why would any one put fiberglass in concrete?
TopamaxSurvivor
206 days ago
