Radial arm saw
Forum topic by Michael smith posted 02-11-2015 01:30 PM 1412 views 0 times favorited 20 replies Add to Favorites Watch
View Michael smith's profile
Michael smith
52 posts in 1169 days
02-11-2015 01:30 PM
Topic tags/keywords: question
I have a 10 inch dewalt radial arm saw. I saw on the New Yankee Workshop, Norm was making 1/2 lap joints using a dado set. The dado set had two blades, some how the blades touch then 180 deg they could be opened up to 3/4.
I have search the web and even e-mail the NYW to get more information on this dado set. No luck.
The response from the N.Y.W. Was to send me to a site, but this site didn’t offer it.
Ther has to be some devise between the the blades that adjust the width of dado cut.
To see this go to you tube new Yankee work shop he is building a shop work bench.
Has anyone see or heard of a dado like this? I am interested in finding one!
Thanks any help appreciate
Mike
-- Http://www.woodworkermike.com
20 replies so far
Michael smith
#1 posted 02-11-2015 01:37 PM
PS
The site is New Yankee Workshop – 102 Work Bench
4947 posts in 2456 days
#2 posted 02-11-2015 01:49 PM
That was one of the very early episodes, I suspect that dado set isn’t marketed anymore….at least I haven’t seen it anywhere. Any of the sets (except one) that wobble got a bad reputation for not cutting perfectly flat bottoms, but most of those were a single blade set up. The one Norm had may well cut flat bottoms, but what would be the advantage over choosing a stacked set? In any case, you might find a second hand one on e bay. but I haven’t seen a new set like that available. BTW, your Dewalt will handle the stacked dado just fine, I do it all the time on mine.
View wheelerspop's profile
wheelerspop
9 posts in 1483 days
#3 posted 02-11-2015 01:57 PM
If it’s the episode where Norm is making the wood working bench, early in the series. Then it’s an adjustable dado blade. I have one that my dad had in the late 60’s, it never made it out of the package. I read that they aren’t the greatest dado device ever made.
Just Google adjustable dado blade and you’ll find many to chose from.
Michael smith
#4 posted 02-11-2015 01:58 PM
Thanks Fred
I was afraid of that. The reason I wanted one is I use pallet wood and most of the wood veries in thickness
And I hope that that dado could be adjusted very fine!
I don’t know how to e-mail a reply to you. ( very new to LJ & computer dumb)
Thanks
Michael smith
#5 posted 02-11-2015 02:02 PM
Wheelers pop
Do you want to sell it?
I don’t know how to e- male on LJ’S
Michael smith
#6 posted 02-11-2015 02:08 PM
Wheelers pop
Is it a two blade? I don’t want a one blade.
I saw all the single blades on google.
Thanks
HillbillyShooter
5811 posts in 2255 days
#7 posted 02-11-2015 02:13 PM
I believe you are inquiring about what was called a “Wobble Dado”. I remember them being made by Sears back in the 60s and 70s, but have not seen or heard about them for some time. Not only were they very sloppy but they created excessive vibration, ergo. “Wobble”. I seem to recall buying one but gave it away after one use. My advice is to forget it and go for a quality stack dado set. By the way, The Tool Nut has the best price I’ve ever seen on Forrest dados, which are top of the line IMHO, c.f. http://www.toolnut.com/SearchResults.asp?Search=Forrest+dado
View Alongiron's profile
Alongiron
647 posts in 2656 days
#8 posted 02-11-2015 02:14 PM
http://www.woodsmithshop.com/download/107/107-dadoblades.pdf
This article may change your mind about getting one of those blades and using it for half lap joints.
I used a stack head dado blade all the time on my RAS. It leaves a nice flat bottom where the adjustable ones leave a curved bottom.
-- Measure twice and cut once.....sneak up on it! Steve Lien
#9 posted 02-11-2015 02:14 PM
The stacked sets come with shims that allow you to fine tune the width of the dado to just about anything you want, down to .001”. Of course within the max width of the set, which is normally somewhere around 13/16”. There is another possibility, the Freud SD608. It’s sortof a combo between a stacked set and a wobble. The stacking gets you close, and then dial the wobble for the fine adjustments. Those who have them (and I’m not one) claim it is a very good dado set. This is the set I alluded too earlier (the “except one” part) and forgot to go back and explain.
View bigblockyeti's profile
bigblockyeti
5086 posts in 1683 days
#10 posted 02-11-2015 02:36 PM
I have an old Craftsman Excalibur double wobble blade that works ok for stuff that doesn’t require a great deal of precision as it’s tricky to fine tune. For most of my dado work I use a stacked dado set by Freud. Freud does make an adjustable dado set that’s supposed to be easier to fine tune and offers flat bottomed cuts, it’s just not cheap: http://www.rockler.com/freud-sd608-8-dial-a-width-dado?utm_source=google&utm_medium=cpc&utm_term=&utm_content=pla&utm_campaign=PL&sid=V9146&gclid=CNWU3s2O2sMCFUojgQodGxIAjA
Michael smith
#11 posted 02-20-2015 11:11 AM
Thanks everyone I will just buy a good dado set. Thanks again for your comments
Mike
View HarveyM's profile
HarveyM
106 posts in 1985 days
#12 posted 02-20-2015 12:36 PM
FYI- there’s a web site that lists the tools Norm used in the NYW here
http://www.normstools.com/normstools.shtml
-- Just a Duffer
Michael smith
#13 posted 02-20-2015 12:42 PM
Thanks Harvey
The one i saw is on there it’s the craftsman 8” dado adjustable.
Thanks that is a very informative site
Thank again. I’ll spend a lot of time looking at it
Mike
View dhazelton's profile
dhazelton
2753 posts in 2259 days
#14 posted 02-20-2015 12:53 PM
I think I have one new in the package I bought back in the early 90s. When you think about it a large unbalanced rotational mass is probably not the best thing for a saws bearings.
Michael smith
#15 posted 02-20-2015 01:01 PM
You will never guess what I tried.
I took a 3 inch hard rubber car body to frame rubber bushing mount.
I ground it into a wedge full thickness at the top and about 1/8” at 180 deg.
I took two identical 10” blades. And mounted them on the arbor with the wedge in between
It cuts 5/8” each pass! I don’t know how safe it is but I am very carful of it.
It is curved at the bottom, so I’ll has to use a chisel to clean the dados up.
I have only made test cuts so far.
I have not started a project yet but plan to
———-just a little innovation you never know what you will come up with
