Drill press runout question
Forum topic by jacquesr posted 02-11-2015 02:44 AM 881 views 0 times favorited 13 replies Add to Favorites Watch
View jacquesr's profile
jacquesr
339 posts in 1330 days
02-11-2015 02:44 AM
Hi guys,
I have had a PC drill press for 4 months, sitting pretty outside of my shop.
Key components were broken, and the arbor could not be installed…
Received new parts, replaced them…. had huge runout… bought a Grizzly keyless chuck…
I think I still have about .0010-.0015 – but when I use a 1 1/4 inch forstner bit (Colt)... I get a 1 1/4 inch home as per my caliper…. Is this a good test to mesure runout?
Am I being anal retentive (don’t answer please).
I intend to do precision work, hence my focus on accuracy.
Sleepless in Montréal
Thanks
13 replies so far
View Ghidrah's profile
Ghidrah
667 posts in 1130 days
#1 posted 02-11-2015 03:08 AM
If you want to minimize run out you need to clamp the project to the table,. I have a Delta 16” and it’s a decent DP does pretty much everything I ask of it. I use metal and wood bits the wood bits, forstner and brad point, I have some brad point bits from the same group that are so off center or bent they’re not good for anything but sinkers or paper weights.
You need to do some experimenting to tie down the culprit, is it still bad with forstners and HSS when the object is clamped? Is the DP base moving around, or is the entire unit rattling/vibrating while the motors running and your not drilling? Is the table secure and square to the bit? Marrow the possibilities down.
-- I meant to do that!
jacquesr
#2 posted 02-11-2015 03:14 AM
The piece was solidly clamped.
Is a Forstner bit a good test?
Thanks for your input.
Ghidrah
#3 posted 02-11-2015 03:42 AM
Can you rattle the chuck/arbor/spindle in the quill?
Pop open the top and watch the belts and pulleys while the motor is running any undue slop between them?
I would then bottom out the spindle and lock it down then set up a dial indicator on the table then remove one of the belts and rotate the spindle by hand from the pulley compartment. Watch the indicator for the run out. It’s possible the quill could be warped.
View jumbojack's profile
jumbojack
1673 posts in 2532 days
#4 posted 02-11-2015 03:52 AM
Really, you are worried about 1 thou?
jacquesr
#5 posted 02-11-2015 04:05 AM
10-15 thou
View Garbanzolasvegas's profile
Garbanzolasvegas
356 posts in 1134 days
#6 posted 02-11-2015 04:07 AM
I have gotten a PC from lows with huge runout. Cant decide it its the chuck or the shaft
-- If you don't Play, you can't win
17564 posts in 1764 days
#7 posted 02-11-2015 04:09 AM
.001 is a thousandth.
View johnstoneb's profile
johnstoneb
2794 posts in 2080 days
#8 posted 02-11-2015 04:15 AM
I have an older Delta runout on it is about .005. It drills an accurate hole. Your working with a material that will move way more than your runout. Your being anal.
Just the manufacturing tolerances in the chuck jaws could give you .001 runout. If you need that kind of accuracy you need to get a mill made for metal work. You can adjust them for zero on setup for each job.
-- Bruce, Boise, ID
jacquesr
#9 posted 02-11-2015 04:22 AM
Thanks! .010-.015 then.
- firefighterontheside
johnstoneb
#10 posted 02-11-2015 01:04 PM
Pictures of where and how you are measuring the runout would help.
-- Bruce, Boise, ID
jumbojack
#11 posted 02-11-2015 02:02 PM
OK .01 IS serious.
First check to see if it is the arbor or the chuck.
View MrRon's profile
MrRon
4634 posts in 3151 days
#12 posted 02-11-2015 05:41 PM
A drill press is not considered a “precision” machine. In the metal working world, if you want accurate holes, you use a lathe or vertical mill. But yes, .0010 to .0015 is too much; even for wood. If you want a precise chuck, you need an Albrecht chuck, but be prepared to pay around $200 for it. The ball bearings on a garden variety DP are general purpose bearings which means .001 to .002 precision. You have clearance between the bearings and the arbor; clearance between the arbor and the quill and the chuck has a runout amount. It all adds up to excessive runout. I have a DP and a vertical mill. If I want an accurate hole, I go to the mill.
jacquesr
#13 posted 02-12-2015 12:46 AM
Alright guys – looks like the arbor was not fully seated.
I have drilled many types of wholes today and the results are excellent.
My calliper shows me exactly 15/32 when I used that bit, and so on.
Quite happy – A drill press is (to me) a simple machine and I was ready to switch for a big Jet.
But my el cheapo PC will do just fine.
Thanks a lot for those who chimed in.
Much appreciated.
