chop saw
Forum topic by Partridge posted 473 days ago 299 views 0 times favorited 11 replies Add to Favorites
View Partridge's profile
Partridge
159 posts in 484 days
473 days ago
I am Thinking of getting chop saw. want something that cuts strait. looking at ridged 12in
-- Do it right the first time. Becuase fixing it is a wast of time.
View Sawdust2's profile
Sawdust2
868 posts in 616 days
473 days ago
I use a Makita dual rail compound miter saw. Got it when my radial arm saw went south.
At the time Lowe’s had it on sale with a further 10% discount if you charged it on Lowe’s card. Saved about $100
View snowdog's profile
snowdog
674 posts in 511 days
472 days ago
I have my old 15 in HITACHI, the damn thing weights a 1000 lbs, well it sure feels like it :) I bought it 20 years ago to cut 6×6 and 2×6 on the flat for miters and it has served me well.
It is time I also buy a new, more versatile chop saw. The compound miter saws look very nice but do I really need to waste the money on a new saw when my current one does the trick (minus the compound miters). I have been trying to talk my wife into a new tool purchase but that is a long process :)
2055 posts in 549 days
472 days ago
This is the one I have been coveting.
I was kind of waiting for an improvement in the digital read out but it’s not too bad the way it is.
The advantage in a small footprint shop is the newly engineered slider that dramatically cuts down the over hang at the back of the saw letting it sit on a narrow bench.
I am at the stage where I am upgrading stuff like this so I will spend a few extra bucks this time and get the best.
hitachi CMS with digital read out and reverse slider
View SteveB's profile
SteveB
23 posts in 586 days
472 days ago
I have the Ridgid 12-inch compound miter saw (http://www.epinions.com/hmgd-Shop_Tools-All-Ridgid_MS1250_Compound_Miter_Saw/display_~reviews), and I’ve been happy with it. The only problem I’ve had was with tearout cutting mesquite molding, so I replaced the blade with a 100-tooth polished cut job. The old blade is great for soft wood.
Now I have my eye on the Ridged miter saw stand (http://www.epinions.com/RIDGID_Miter_Saw_Stand_AC9940/display_~reviews).
-- Steve B - New Life Home Improvement
View TheGravedigger's profile
TheGravedigger
199 posts in 552 days
472 days ago
I use a Delta 12” compound miter saw. The big advantage to me is Delta’s built-in two laser system. It projects a pair of lines on the stock that are adjustable to exactly match the kerf of your blade. In other words, whatever is between the red lines just disappears. Makes precise cuts a lot easier.
The saw handles up to about 8” stock. However, the laser system makes flipping a board to complete a cut MUCH easier.
The blade? Ehh…it’s ok, but I’ve got my eye on a Forrest Chopmaster as an upgrade.
-- Robert from Raymond, MS. "We are what we repeatedly do. Excellence is therefore not a practice, but a habit." - Aristotle
View WayneC's profile
WayneC
5684 posts in 625 days
472 days ago
I have a Makita LS1013L 10-Inch Dual Bevel Sliding Compound Miter saw. Great saw. It is mounted on a Rigid miter saw stand.
Makita Compound Miter Saw
View Mario's profile
Mario
731 posts in 579 days
472 days ago
I have a DeWalt and really like it.
-- Hope Never fails
View woodspar's profile
woodspar
684 posts in 627 days
472 days ago
If you get a 10 inch, you can swap blades with your table saw. (unless you have a 12 table saw.) I think most of the miter saws are good – I have a delta that works pretty well. I would recommend that you check the table and turn table for square and true, mine was a bit off. You should set up the saw when you do a cut; don’t believe that the manufacturer made it perfect.
I calibrate mine often (get a good square) and I always get square, clean cuts.
I recommend a Freud 80 tooth blade for most woods, perhaps fewer teeth for the more dense hardwoods.
Just an F.Y.I., Fine Homebuilding just reviewed miter saw stands in the August/Sept issue
http://www.taunton.com/finehomebuilding/how-to/video/miter-saw-stands-tool-review.aspx
Here is an article on choosing and using a miter saw:
http://www.taunton.com/finehomebuilding/how-to/articles/choosing-using-miter-saw.aspx
-- John
472 days ago
Thanks John and kudos to Taunton Press.
They got it right this time by not trying to pick the best solution from a limited selection of saws as they have often in the past.
I think the author, Clayton DeKorne is pretty incisive as well in pointing out what is needed in this tool.
View Thos. Angle's profile
Thos. Angle
3409 posts in 490 days
472 days ago
We have a 12” DeWalt mounted on a table top with an 8 foot table fitted with a Kreg measuring system on the fence. We also use a 10” Hitachi mounted on a Ridgid wheel stand that we take to job sites. I like the 12” DeWalt because I can zero it in both directions pretty easily. The Hitachi belongs to my son-in-law and we keep it strictily for trim work. I’ve not tried the sliding saws but have heard from others that they are harder to keep in trim.
View Dorje's profile
Dorje
1749 posts in 525 days
472 days ago
I have the Makita (the one Wayne posted a pic of above) and just love it…the stock blade is very good too…(usually have to put a good one on right away).
Bookmark And Share This Page
