Calling all woodwork physisists!
Forum topic by albachippie posted 02-10-2015 03:51 PM 1881 views 0 times favorited 37 replies Add to Favorites Watch
View albachippie's profile
albachippie
772 posts in 3005 days
02-10-2015 03:51 PM
Topic tags/keywords: planer thicnesser
I have recently started a new job in a machine shop in a local college. I am responsible for the machines and their safe use by students. I would like to make a point to the students about eye safety, particularly while using the planer thicknesser. I want to know, roughly, how fast would a wood chip be travelling whilst being ejected be the planer drum, which is rotating at 5000rpm? I see the students, and lecturers for that matter, standing over the machine, screwing their face up because there are chips flying straight at their face. Why not wear safety glasses,which I have made readily available at all machines, I just don’t know. I have seen a thread regarding the use of safety gear on TV on LJs, and I agree. These are guys and girls starting out in their chosen trade, who are going to need their eyes for the rest of their lives.
Anyway, any ideas????
Garry
-- Garry fae Bonnie Scotland
37 replies so far
View MrRon's profile
MrRon
4722 posts in 3213 days
#1 posted 02-10-2015 04:00 PM
No safety glasses, no entry.
View descolada's profile
descolada
54 posts in 1767 days
#2 posted 02-10-2015 05:18 PM
Assuming a 4” diameter cutterhead, the chips should be flying out at about 60mph. Twice the diameter equals twice the speed.
Or what MrRon said.
View Redoak49's profile (online now)
Redoak49
3202 posts in 1958 days
#3 posted 02-10-2015 05:20 PM
I agree with no safety glasses no entry.
MrUnix
6612 posts in 2168 days
#4 posted 02-10-2015 05:32 PM
How do you stand over a planer when feeding wood and why would the chips be coming straight up? Pretty much every planer I’ve ever used shoots them out the opposite side of feed, away from the operator. But yeah, glasses should be required in order to use any machine in that type of environment, regardless of where the chips may fly. That has been the rule in every shop class I’ve ever been in or seen.
View TheFridge's profile
TheFridge
9255 posts in 1455 days
#5 posted 02-10-2015 05:40 PM
- Redoak49
Pretty much
View Julian's profile
Julian
1308 posts in 2660 days
#6 posted 02-10-2015 05:52 PM
This should be a rule established by the department manager (or who ever is responsible) and enforced by the instructors. I would also suspect you could find an OSHA regulation on the use of personal protective equipment (i.e. safety glasses, etc…). All OSHA regs. are on the internet.
-- Julian
View agallant's profile
agallant
551 posts in 2856 days
#7 posted 02-10-2015 05:54 PM
View JoeinGa's profile
JoeinGa
7735 posts in 1976 days
#8 posted 02-10-2015 06:20 PM
I would bet that an OSHA inspector would FREAK OUT if he came into a woodworking shop and no one was wearing safety glasses. Same for most manufacturing plants. Every one I’ve worked at had signs on all the doors saying “Safety Glasses Required Beyond This Point”
View Yonak's profile
Yonak
986 posts in 1490 days
#9 posted 02-10-2015 06:38 PM
Where’s the dust extraction ? That’s a negligent situation to have it shooting to the air.
View Ghidrah's profile
Ghidrah
667 posts in 1192 days
#10 posted 02-10-2015 06:54 PM
Even with a vac running, chips can and do get stuck up in the carriage then drop down onto the board being planed then ejected out the infeed side. The spinning cutter head with knives standing out an 1/8” acts just like a rotating fan. It happens when multiple boards are making multiple passes to dim.
All planers are set to eject without DC, you can buy the attachment to connect a DC hose or not. Not recommended but doable. My JPM came with the dust shoot, I had to buy the shoot separate for my Delta 12”
-- I meant to do that!
View HornedWoodwork's profile
HornedWoodwork
222 posts in 1184 days
#11 posted 02-10-2015 07:40 PM
I would create a certification program. A person must be trained and certified by an instructor to operate that machine, must pass a written test, must agree to use the PPG provided, and can have their certification revoked if they are observed misusing the machine or failing to wear PPG.
-- Talent, brilliance, and humility are my virtues.
View Shadowrider's profile
Shadowrider
183 posts in 1179 days
#12 posted 02-10-2015 07:43 PM
Knowing the RPM and the diameter of the cutterhead you can figure the surface speed in feet per minute. That’s how fast the cutter teeth are moving so the chip is going that fast as it leaves the cutter.
(RPM x DIA)x 3.1416/12
Edit: Dang software won’t let me type asterisks
View bondogaposis's profile
bondogaposis
4690 posts in 2321 days
#13 posted 02-10-2015 07:54 PM
I come out w/ 86 fps (feet per second), assuming a 4” cutterhead, which is probably more meaningful than mph. So if a persons eye was 18” from the cutterhead it would take .017 seconds for a particle of wood to reach the target eye, far faster than anyone can react or even perceive the hazard. Wear safety glasses.
-- Bondo Gaposis
MrUnix
#14 posted 02-10-2015 08:03 PM
It may leave the cutter at that speed, but will very quickly slow due to air resistance, shape and light weight of the chips themselves.. and I doubt anyone is going to have their head just a foot and a half away from it! Still not an excuse.. safety glasses need to be worn and should be required to use any machine that shoots out chips or has any potential to do so, regardless of how fast or slow they may be coming at you.
albachippie
#15 posted 02-10-2015 08:21 PM
Thanks all for your input. The extraction is very efficient, but, as Ghidrah says, the best extraction in the world wont stop stray chips. I have been round machinery long enough to know you can’t be too careful. This is the machine in question.
It has a 520mm wide cutter head, with 4 knives, which, as I say, rotates at up to 5000rpm. I have signs, I have glasses everywhere, and I have talked to the lecturers, urging them to insist on safety wear. The college have policies in place, as laid out by the HSE (Health and Safety Executive) but enforcing this is proving to be challenge.
showing 1 through 15 of 37 replies
