Dust collectin and plastic pipe
Forum topic by snowdog posted 210 days ago 1068 views 1 time favorited 41 replies Add to Favorites Watch
View snowdog's profile
snowdog
808 posts in 876 days
210 days ago
Topic tags/keywords: dust collection plastic
I read somewhere (here probably) that pastic pipe for duct work can be dangerous to ones survival, a static charge can build up and BOOM! no more shop. How over rated is this fear? Mettle seems to be very expensive and plastic so very cheep.
Any cost effective alternatives or can I build with plastic?
20×20 garage shop
JET DC-1100, 1-1/2 HP 1,100 CFM Dust Collector with Remote and Canister
I sure am tired of all the plastic hosing on the floor :)
View Durnik150's profile
Durnik150
536 posts in 215 days
210 days ago
You can pick up an anti-static/grounding system at any woodworking shop or on-line. It works like a lightning rod in a home by discharging any build-up. I don’t have one installed in my system and every once in a while I get a good annoying zap. I don’t work with any fumes or flammables so have not put it high on my priority list. The grounding system might be a good alternative to investing in ductwork.
-- Behind the Bark is a lot of Heartwood----Charles, Centennial, CO
209 days ago
After reading and participating in ANY discussions on this subject I have an opinion.
You may have as much caution as you will in regard to opinions.
You may also know some of the things they say about opinions.
Anyway, here goes.
There isn’t much liklihood that there would be enough charge built up in a home shop based DC to create a spark.
If such a thing did occur (very unlikely, I repeat) there is a similarly low liklihood of ignition of dust.
The causes of ignition in small and medium sized DCs can be blamed, for the most part, on ferrous metal drawn into the system, striking the impeller wheel and thus staring a small fire. Tools can also start fires by striking a nail or screw and then the sparks get sucked into the DC piping. But the chance of having those sparks stay hot enough to start fires is very low, too. Think about it. These little sparks MIGHT ignite nearby wood dust IF there is not a lot of moving air in the area, but a DC pulls a lot of airthrought the area and the tiny sparks cool quickly.
Careless smoking has also been the source of ignition in DC systems, especially in schools where the student may be sneaking a smoke in a bag house.
I have yet to hear of a properly documented case of static electricity generated in a home shop DC starting a fire or explosion. Dust explosions CAN happen in very large scale environments like grain elevators, but even they are rare.
That’s all!
d
-- If a man says something in the forest and there's no woman to hear it, is he still wrong?
View Tony Z's profile
Tony Z
173 posts in 683 days
209 days ago
I have 4” PVC plastic run throughout my 20×24 shop. I’ve never had a spark or any hint of a static shock. I would highly recommend using PVC. And my shop is in the basement so if I get a fire, my whole house burns down. I’m not worried at all. It’s cheap and easy to work with. Go for it.
-- Tony, Ohio
View CessnaPilotBarry's profile
CessnaPilotBarry
1263 posts in 596 days
209 days ago
Food for thought
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
View interpim's profile
interpim
445 posts in 351 days
209 days ago
My stepfather used to work in a furniture factory (Broyhill), he was laid off since they moved a majority of their operations overseas. But I do recall the Sawdust building blowing up once. This building is basically 250’ long by 50’ wide, one end is open for trucks or front end loaders. The saw dust is dumped in by giant piping feeding into the roof and dumping on the floor. Lucky nobody was in the building when it happened.
-- San Diego, CA US Navy
View WhittleMeThis's profile
WhittleMeThis
67 posts in 266 days
209 days ago
I have metal pipes but only because i couldn’t find 6” schedule 20 S$D in my area, I think the latest thoughts are that PVC is safe and the fire danger is fairly small. I have also read the anti-static system are fairly ineffective but couldn’t hurt.
The following web site may help
http://home.comcast.net/~rodec/woodworking/articles/DC_myths.html
View Julian's profile
Julian
688 posts in 418 days
209 days ago
I have 6” pvc in my system, and I used to get shocked from the static charge all the time if I was close to the flex pipe running from the machine to the pvc pipe. To remedy it, I just wrapped a piece of stripped copper electrical wire around the last foot of flex pipe, and hang it on a piece of metal on the machine I am using. Problem solved.
-- Julian, Park Forest, IL
View JimmyC's profile
JimmyC
110 posts in 295 days
209 days ago
MIT did a study on the explosion factor of PVC with dust collection and their study showed that the chance of an explosion happening was pretty much nil. But the chance of getting a static shock on ungrounded pipe is high, but just uncomfortable for the recipient not enough to cause an explosion. There is a much bigger danger in picking up a screw or something causing a spark ,or causing it to get hot, while passing through the DC impeller. This can eventually start a fire in your dust bin or bag.
Good Luck.
-- -JimmyC...Clayton,NC- "Just smile and wave boys, smile and wave"
View Woodchuck1957's profile
Woodchuck1957
950 posts in 657 days
209 days ago
A 1 1/2 hp portable DC is probably a little on the light side for a overhead layout. You will want to keep ducting to a minimum, use large radius elbows, and kept them to a minimum number of also. Mounting the blower on the wall close to the cieling will shorten the main branch and eliminate elbows. Or you could buy a 2 hp Cyclone which are built more for overhead layouts.
View Bartee's profile
Bartee
14 posts in 637 days
209 days ago
I have a 6” PVC installation. It works great. I used screws and friction fit on most connections.
I have had NO problems with static.
This keeps coming up. In all the discussions I have read NO ONE has ever had a problem with any kind of explosions. I once read a post from a fireman who had never heard of a problem with home shop pvc static causing a fire.
All of the manufacturers are covering themselves legally with statements and warning in their warranty documents.
So…. I think PVC is great. Easy to work with and a great solution.
Here is my install LINK
Dick, & Barb Cain
7033 posts in 1192 days
209 days ago
I used to use pvc for my dust collector, but have recently switched to metal.
Here’s a good article on about grounding, in WOOD Magazine.
View stahlee's profile
stahlee
2 posts in 218 days
209 days ago
I also use PVC (ASTM 2729) with no problems. There hasn’t been one case where PVC has caused any explosions, it’s safe. The static shock can be a PITA, but there are ways around that.
Go ahead and use it if it’s cheap in your area.
View odie's profile
odie
1601 posts in 733 days
209 days ago
I have read that plastic has a natural “drag” to it, and metal is the best. You lose a little CFM with plastic I’ve read. Metal is inherently anti-static. There are anti-static grounding kits sold everywhere if you go the PVC route.
View sIKE's profile
sIKE
1094 posts in 647 days
209 days ago
I am using 4” PVC. I grounded both inside and out and tied to the cold water pipe that is in my shop. I am planing on re-working my dust collection to my shop. When I do, I am going to pull out the grounding wires from inside the pipe and just leave the wires on the outside. The wire inside of the pipe catches too much junk.
This has been discussed mutiple times on this site and the conclusion seems that you don’t need to ground at all. However the DC will then be prone to static electricy dischages to the end user. :) I don’t like that and have already invested in the wire so I am going to use it to help keep this end user from getting litely zapped all of the time.
Woodchuck1957
209 days ago
Odie, I could believe the drag factor. I wonder if Blankman has a calculation for that too. lol
Dick, & Barb Cain
209 days ago
One thing I didn’t like about the plastic it always accumulated dust on its surface.
But maybe that’s a good feature.
It’s attracting all of the fine dust that gets missed by the suction.
Julian
209 days ago
People overanalize this too much. The only problem you’ll get is static shock if you touch the flex tube from the machine to the pvc. Just wrap a piece of wire around the end, and hook the other end onto the machine you’re using. Problem solved, no more shock since the machine now grounds the line.
I think that running a wire inside the pvc is a bad idea, and could lead to clogged lines.
View poroskywood's profile
poroskywood
198 posts in 257 days
209 days ago
Dust explosions are mainly caused by extremely poor house keeping. Years of fine dust build up. Blow your rafters off once a month.
-- There's many a slip betwixt a cup and a lip.--Scott
Dick, & Barb Cain
209 days ago
I don’t recommend blowing, you just put more dust in the air that you’re trying to keep from breathing, cough, cough!!!
Use a vacuum
View pinkfish's profile
pinkfish
129 posts in 564 days
209 days ago
I have just been reading this site, which is a bit of an eye opener in terms of dust collection:
http://billpentz.com/woodworking/cyclone/index.cfm
He has a cyclone design you can build from sheet metal as well.
View Padre's profile
Padre
259 posts in 382 days
209 days ago
I have 6” PVC, no problems.
-- Chip -- Manchester, Connecticut "When the power of love overcomes the love of power, the world will know peace."
snowdog
209 days ago
Thanks all,
I will use the PVC and probably rap it with some light copper to negate the PITA factor. With just a little luck I will get this done this summer. The plan is sooner than later but then that is always the plan :)
View MyOldGarage's profile
MyOldGarage
95 posts in 320 days
208 days ago
I’m going to do some overhead ducting myself and I’m just going to run it across and not worry about grounding at all. I’ll have mine nestled right next to my I-beam for the house, so I figure it might bleed off any static on the surface.
-- Bradley Miller, Blue Springs, MO - http://myoldgarage.blogspot.com
208 days ago
Just to complete my thinking on this subject -
The only disastrous dust explosions I ever heard of were not (apparently) the result of the containers or conduits of he dust (IE- the piping) but rather the result of static charges built up on the dust particles themselves.
Consider the case of an explosion in a grain elevator.
It isn’t that the piping is an ungrounded or ungroundable material, it is the buildup of an enormous cloud of dust in the storage silo, usually when the silo isn’t full. That allows for a very large cloud. Think of a volume much bigger than your house and a couple of hundred feet high.
But, you may ask, “where does the static buildup take place?”
Here’s where.
I recently saw a picture of a volcano spewing a cloud of volcanic ash high in the sky. It was in a magazine like National Geographic, I think.
At any rate, the remarkable thing was the tremendous display of “lightning” in the dust cloud. Very much like ordinary lightning, it was the result of the dust particles rubbing against one another.
Now, think about your (comparatively) tiny dust collector.
How much static are you going to generate? Enough to give you a little zing if you touch a PVC pipe? Sure. But I’ve experienced some very large shocks just getting out of the car and touching the door handle. I don’t think, however, that it’s enough to fire off an explosion in the relatively tiny dust cloud in my cyclone DC.
In fact it’s a charge in the wrong place to fire off a dust fire. The dust itself needs to be charged in order to do that and it needs to be larger by orders of magnitude!
Well, I believe that’s the last thing I want to say on the subject. It’s been gone over many times and its unlikely my thoughts will change the minds of those convinced otherwise.
d
CessnaPilotBarry
207 days ago
To those who are planning on spending time and money “grounding” PVC pipe: Before you spend the time, effort, and money, please read the link posted by WhittleMeThis and myself. Read the entire article, then make your decision.
An interesting side note that has developed over the last few years, supporting the MIT employee’s writings, is the plastic cyclone body. How would you “ground” a plastic cyclone body? ;^)
The fire hazard folks should really worry about are sparks caused by sharpening on the belt sander, blades that hit steel nails and screws, cigarette butts sucked into the system, etc…
JimmyC
207 days ago
CPB, I didn’t even think about cigarette butts, that cracked me up because I know smokers that are dust conscious, lol.
CessnaPilotBarry
207 days ago
I’m not a smoker, but plenty of woodworkers are.
We had a local shop who had a DC fire from a cigarette in the collection bag. The scary part is how long a butt or sharpening spark can smolder in the bag / can…
Dick, & Barb Cain
207 days ago
I learned my lesson about not using the dust collector for metal once.
I was sharpening an old beat up chisel, & all of a sudden my shop was full of smoke.
It was coming from the lower bag of the collector.
I immediately removed the bag, & took it outside.
There was a small 4” patch of sawdust smoldering inside.
I was lucky, because I was just going to take a lunch break.
I could have lost my shop.
Woodchuck1957
207 days ago
Floor sweeps I’m not sure are a great idea either.
207 days ago
My little fright with smoke and smoldering embers wasn’t in the DC, but it taught me the seriousness of having a smoke alarm in the woodworking shop.
I had been cutting a thick workpiece on the tablesaw, but I had forgotten that there was a blade stabilizer disc mounted on the arbor. Moreover, as is my habit, I was using a zero clearance insert on the machine.
When I raised the blade high enough to cut the workpiece I didn’t realize the stabilizer would rub against the ZCI. But it did. And it created enough heat to start a small ember in the cabinet below.
Just after that I went into the house for dinner.
My wife, whose nose is astonishingly sensitive, remarked that she smelled smoke.
I went into the shop (after searching the rest of the building) and found it filled with woodsmoke. When I discovered where it came from I discharged the fire extinguisher into the saw cabinet and raked out the sawdust that was smouldering there.
My heart squeezed me a bit and I wondered how I would tell Marge without sending her into a panic. I managed to break it to her gently, saying it was a minor matter and assuring her I would mount a smoke detector immediately.
This is only a bit off topic because it still deals with the possibility of losing everything in a fire in the woodworking shop.
Please, everyone, remember that our medium, wood, well dried wood for the most part, is flammable and we owe it to ourselves and our families to be as careful as we can be.
Don
View magicman's profile
magicman
48 posts in 502 days
207 days ago
I used to work in a factory that made taillights for cars. When the plastic parts came down the line they were very hot and the plastic firm we put on them generated a lot of static. When we would ship them out in these huge medal containers, you could hold your hand an inch away from it and see the static spark jump from you the box to you finger. It would make your finger hurt. What we did was take a copper wire and attach two clips on each end. Clip one end to the box and the other to something else, BINGO you just grounded the object. I don’t see why this would no work on the plastic pipe.
-- Twenty years from now you will be more disappointed by the things that you didin't do then by the ones you did. - Mark Twain
View CreekWoodworker's profile
CreekWoodworker
169 posts in 191 days
114 days ago
Don,
I know it’s not a laughing matter, but I just read your comment on this forum. I can picture myself trying to tell my wife, it was only a small fire, nothing to worry about. It gave me a good laugh tonight. My wife didn’t think it was so funny, ...go figure.
-- Mike the CreekWoodworker
16683 posts in 470 days
114 days ago
I’ve been running PVC for years with out problems,
View dbhost's profile
dbhost
600 posts in 125 days
114 days ago
I’ve seen and read too many discussions on this particular subject. I know it’s a risk to run PVC pipe, but then again so is waking up in the morning. Run the pipe you want and go on living. Worrying about it probably has better odds of harming you or your property than the potential for fire from PVC pipe…
-- Trying to follow the example of the master.
View MNWOODWORKER's profile
MNWOODWORKER
36 posts in 478 days
112 days ago
I have had PVC in my shop for years. Because you are always going to hear good reasons to believe either argument, I ran a ground wire through mine from my DC to each tool. I just bought a 50ft roll of 12/2 wire and took the ground wire out, then stripped as much of the plastic insulation off the other wires as I needed to finish the job. I made sure that there is no splices inside the tubing, only at the tool to reduce the chance of a clog. Knock on wood in all the years I have had mine I have never had a clog, I did put in a couple Y’s just in case I ever do then I can just snake it clean. Have fun.
Nate
MNWOODWORKER
111 days ago
By chance I listened to an old Wood Talk Online and came across this episode that talks about this topic and gives a nice link that might answer your ?’s a little more. Hope it helps.
Nate
http://thewoodwhisperer.com/woodtalkonline/episode12
111 days ago
404!!!
View GuyK's profile
GuyK
141 posts in 972 days
111 days ago
Snowdog, if you look at the pictures of my shop, I have PVC running along the wall to the bench tools. Never had a problem or even a hint of one.
-- Guy Kroll
snowdog
109 days ago
I know I started this thread a while back but I just got my PVC up inside the suspended ceiling, now I have to connect all the fittings. Dang I am moving slow on this :)
View Abbott's profile
Abbott
203 posts in 196 days
109 days ago
PVC 25 years, no troubles.
The issues are only for larger commercial operations, home shops do not generate the proper combination of elements to cause problems.
-- Still clinging to my guns and religion.
View Chris Wright's profile
Chris Wright
360 posts in 374 days
109 days ago
My father has PVC in his shop, he ran copper wire through it to ground it. The only issue he’s had was when he was planning a lot of pine. The chips are very light and the little bit of static that built up cause the system to clog a few times. He just unhooked the system from the planner while he was planning the pine and swept up afterwards. Just an FYI, static will build up in a metal system too, I’ve been zapped a few times by ours, nothing big though. You should be fine with just PVC.
-- "At its best, life is completely unpredictable." - Christopher Walken
