Forum topic by Graham | posted 04-26-2009 11:42 PM | 2154 views | 0 times favorited | 19 replies | ![]() |
Topic tags/keywords: accuracy crosscut question tablesaw joining Hello, Let me apologize in advance for my woodworking ignorance. I made a few crosscuts with my new Steel City 35905 table saw, using a couple of scrap 1” x 3” red oak pieces that I had laying around to practice with. I crosscut them into 3” to 5” lengths. Using a Wixey digital caliper I measured the resulting lengths. They varied from within 0.000”-0.005” of the desired lengths. I have absolutely zero experience in woodworking, but have a fair amount of metal working experience. Would a cabinet maker consider the measured variance poor, average, good, or excellent? Kindly, |
19 replies so far
#1 posted 04-26-2009 11:50 PM |
What type of crosscut sled were you using? I can get dead on accurate crosscuts with my crosscut sleds I built. Just look at my projects, and you’ll get an idea of what you should have. That said, you also need to make sure the blade is dead on parallel with the miter slot before you can get accurate cuts. When checking your saw for runout, make sure to measure the distance from the blade to the slot using the SAME tooth on the blade. This will cancel any arbor runout or blade deflection that you may have. -- Julian, Park Forest, IL |
#2 posted 04-26-2009 11:53 PM |
Thanks Julian, I don’t have a crosscut sled. I am using an Incra Miter gauge to make the cuts. There is about 0.001” of runout, as measured from the same point on the blade, from the miter slot. |
#3 posted 04-26-2009 11:58 PM |
Wow that’s some really nice work on your project pages! I’ll have to put a crosscut sled on my project list. It looks quite useful. lol and I have just made my first few cuts ever! |
#4 posted 04-27-2009 12:52 AM |
To put that into perspective that is over 1/3 of 1/64th of an inch. So go get your ruler and look at the 64th side, divide one of those segments you have trouble seeing into 3 parts and thats the amount of difference your seeing. Also, unless someone trained you on using calipers your probably injecting a good amount of error into the reading yourself. |
#5 posted 04-27-2009 01:22 AM |
yea. It’s pretty small, but is that considered exceptable by cabinet making standards? For most metal working it’s not, which is where my experience lies. Thanks again. |
#6 posted 04-27-2009 01:41 AM |
Just a disclaimer I’m pretty new to woodworking as well but here’s my thoughts. I’d say for almost all woodworking applications (especially things as big as cabinets) that is more then accurate enough. Since wood has can expand and contract with varying environmental conditions measurements this small would be meaningless to a cabinet maker. The only time I might be worried about measurements that small is on very small, precise puzzles and then you certainly wouldn’t be making those cuts with just a miter gauge (check out this guys cross cutting sled http://www.instructables.com/id/Precision-Puzzlemaking-Primer----Volume-1/). |
#7 posted 04-27-2009 02:02 AM |
.001 runout is acceptable for the blade to miter slot. The runout you have with your incra is not bad. It’s not perfect, but it will work well for you since you are just starting out. I suggest looking around the forum for table saw safety tips, and tricks. There is a wealth of knowledge, and a great group of people here to share with and learn from. -- Julian, Park Forest, IL |
#8 posted 04-27-2009 02:09 AM |
As gwebb said, wood moves so any measurement you take will change depending on humidity, time of day, if you looked at it funny. .005 is fine for a some metal working too, I’ve welded gaps bigger than that. Machining not so much, depending on spec. Just to be sure you can also check how much runout you have at the arbor flange, if thats excessive you can clean that up a bit. |
#9 posted 04-27-2009 02:11 AM |
There is much talk on these type of forums regarding tolerances, with some people shooting for a couple thou in accuracy. This is pointless in woodworking due to the nature of wood, and it’s ability to absorb and lose moisture, and the resulting changes in net sizes. We ain’t building the space shuttle. |
#10 posted 04-27-2009 02:30 AM |
If it can be done on a miter saw, thats where I go. |
#11 posted 04-27-2009 03:54 AM |
Thanks folks. As a software and motion control engineer I am used to working with non-organic materials like tungsten and various steels on the order of 1/10000 of an inch. As a newcomer to woodworking I have not established a reference tolerance. I have spent the last month completely rebuilding my new table saw, becuase the manufacturing and engineering is so shoddy compared to what I am familiar with. I am trying to establish, from seasoned woodworkers, if I should tweak the saw more or would it be good enough for an expert craftsman as I have limited experience with organic materials Thanks, |
#12 posted 04-27-2009 04:13 AM |
0.001 runout on the blade/miter guage is considered more than adequate for fine woodworking. with wood movement and esthetics, I think keeping a working scale of 1/64th for parts should be good enough – I believe that in reality, most times you get much better results than that, also thats what I’m seeing in your post (0.005” variations)... sounds like you got it tuned enough in my opinion, I wouldn’t worry about it too much. althought, I’m surprised you’re getting those variations using an Incra miter gauge… heres what you should check: 1. miter gauge bar has no slop in the miter slot – use the plastic expandable washers to tighten the bar up. in addition you could: 3. build a cross cut sled – using 2 runners, would eliminate more of that sloppiness in the slots, and give you a better safer way to crosscut in general or even: 4. (as woodchuck suggested) use a mitersaw for cross cuts, if you really want the safest, and easiest way about it (space and budget allowing it) -- ㊍ When in doubt - There is no doubt - Go the safer route. |
#13 posted 04-27-2009 04:14 AM |
A master rifle maker once told me about tolerances, if it’s not distracting to the piece, it’s close enough. -- Bob in WW ~ "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence |
#14 posted 04-28-2009 05:05 AM |
Thanks PurpLev and Topa. That helps me start to establish a tolerance reference. I was able to get the blade runout down to less than 1/4 of a thousandths, which is about down to the noise in the indicator. After reading my initial post I don’t think I was clear. All of the pieces cut to the exact same length were dead nuts on relative to each other, but the absolute length was off by 0.000” to 0.005”. So it is extremely repeatable, but not completely on in absolute terms. Tomorrow my Oneida Dust collector arrives, so I am pretty excited about that. On Friday my Incra TS-LS table fence arrives. Be well, |
#15 posted 04-28-2009 05:37 AM |
Wow…for a guy just starting out in wood working, your starting off with some good tools. -- Don S.E. OK |
Forum | Topics |
Woodworking Skill Share
12033 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4906 |
6695 |
28062 |
CNC Woodworking
212 |
Hand Tools
5412 |
Jigs & Fixtures
1420 |
Wood & Lumber
6233 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4758 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8846 |
