If you were going to cut this joint. what wood you use?
Forum topic by Partridge posted 473 days ago 304 views 0 times favorited 15 replies Add to Favorites
View Partridge's profile
Partridge
159 posts in 484 days
473 days ago
1”Tx 3 1/2”W x 5’3L Angles are 45deg.
This is a joint I used to connect two rough cut cedar trim)out side) boards in the center (at the top) of my shop door (9’x10’). Looks good, although I could better the cuts on the next one.
-- Do it right the first time. Becuase fixing it is a wast of time.
2055 posts in 549 days
473 days ago
Cedar?
View edp's profile
edp
102 posts in 488 days
473 days ago
Table saw, hollow chisel mortiser and…..........cedar?
Ed
-- Come on in, the beer is cold and the wood is dry. www.crookedlittletree.com
View Dorje's profile (online now)
Dorje
1749 posts in 525 days
473 days ago
Not exactly sure what you’re getting at but I think you’re talking joinery…
I’d cut the male part with a hand saw (prob. a Japanese crosscut saw) and clean it up with bench chisels, lay out the female part, cut out the waste with the band saw or coping saw and then chop to the lines (which would have been marked with a knife and pared to the lines to begin with to keep it crisp).
Is that what you were going for?
How did you do it?
View Zuki's profile
Zuki
924 posts in 605 days
473 days ago
I would use a christmas tree bit in my router. :-)
Well . . . it looks like a christmas tree to me.
Neat joint though.
View Sawdust2's profile
Sawdust2
868 posts in 615 days
473 days ago
Ah, yes. The infamous Christmas Tree router bit.
ROTFL
View Thos. Angle's profile
Thos. Angle
3409 posts in 490 days
473 days ago
Yeah, Dorje, what you said. I want one of those Christmas tree bits too, Zuki. Send it freight collect. and it is a neat joint
View Zuki's profile
Zuki
473 days ago
I actually have 2 extra bits. Santa is dropping off a load of elf wood this weekend . . . I will ask him to swing by you guys and drop them off.
View john's profile
john
801 posts in 909 days
473 days ago
Laser cutter would probably do the job ?
-- John in Cranbrook http://www.extremebirdhouse.com ....http://community.webshots.com/user/cranbrook2
View scottb's profile
scottb
3037 posts in 855 days
473 days ago
Nice one Zuki.
Laser or Plasma cutter would definatley do the trick.
though a pull saw and chisel or two would work for me
-- I am always doing what I cannot do yet, in order to learn how to do it. - Pablo Picasso -- http://snbcreative.wordpress.com/
View Bob Babcock's profile
Bob Babcock
1807 posts in 614 days
473 days ago
I’d use my light saber…...or what Dorje said…:)
Partridge
473 days ago
thank you for the input.
joint was done with jigsaw and wood rasp…. first on. Neve thought of mortising bit or light saber….
It is need to read that there is choices
Sawdust2
472 days ago
I can see da joint in cedar. Looks like it will be a poplar joint.
Because it is trim you could use wall nut.
I guess the first one would be cherry.
If you cut it in the other direction it would be oak (A OK)
And if for a window it would be sASH.
Oh, Partridge, did it come from a pear tree?
Plum pretty.
View snowdog's profile
snowdog
674 posts in 510 days
472 days ago
I would like to see a real picture when your done.
Where can I get the Christmas tree bit? I looked on rockler but coud not find one :)
As of today there is 139 days to Christmas :) www.snowdog.com
472 days ago
Try this one
It cuts extremely thin kerfs straight through the wood.
You could stack the pieces in a jig and cut them using a pattern.
I have one of these and she’s a beauty.
bob
12248 posts in 688 days
472 days ago
sounds like everyone is in holiday mood .. pretty chipper and humorous bunch we have lol :)
light saber.. haha
Bookmark And Share This Page
