wooden mallet
Forum topic by daddywoofdawg posted 02-08-2015 08:23 PM 740 views 0 times favorited 3 replies Add to Favorites Watch
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1599 days
02-08-2015 08:23 PM
Topic tags/keywords: joining
I’m making a wooden mallet laminate (krenov) style.I the center cuts are 2 degrees;I can figure that out.Where my question comes up is cutting the handle how do you cut the 2 degree into the upper part of the handle?should be easy but my brain isn’t wrapping around it.a link to photos or video a plus.
Pretty much going with this plan:
http://lumberjocks.com/projects/53822
3 replies so far
View ElChe's profile
ElChe
630 posts in 1361 days
#1 posted 02-08-2015 08:46 PM
Here’s my thought. Handle is fairly squared to match the bottom mortise for a tight fit and wedge the top of the handle with two wedges. Band saw two cuts in the handle and drill a hole at bottom of each cut to prevent it from splitting and then the wedges spread the top of handle for a tight fit. The wedges should match the angle of the mortise.
View johnstoneb's profile
johnstoneb
2938 posts in 2197 days
#2 posted 02-08-2015 08:51 PM
x1 ElChe. The mallets I made I just did as ElChe suggested.cut them straight to fit the bottom part of the mortise cut 2 narrow slots and glued and drove in two wedges the cut and sanded smooth works great. I put some glue on the handle also. The handles will never come out.
-- Bruce, Boise, ID
View lepelerin's profile
lepelerin
495 posts in 2349 days
#3 posted 02-08-2015 08:53 PM
you could use a hand plane
