Sharing Information - American Rotary big sale
Forum topic by bonesbr549 posted 02-08-2015 03:40 PM 920 views 0 times favorited 6 replies Add to Favorites Watch
View bonesbr549's profile
bonesbr549
1531 posts in 3031 days
02-08-2015 03:40 PM
Wow, got a flyer i the mail that American Rotary is running a presidents day sale of 16% Off.
If you need a 3phase converter, they are at a heck of a discount. Heck they are cheaper now than when I got mine a few years back.
Great quality.
BTW I have no association with them, just a satisfied Customer.
View crank49's profile
crank49
4030 posts in 2935 days
#1 posted 02-08-2015 10:02 PM
Don’t knpw why I would want a rotary phase converter.
VFDs are so much more capable, versiitle, and affordablw.
View TheGreatJon's profile
TheGreatJon
337 posts in 1197 days
#2 posted 02-08-2015 10:35 PM
A single rotary phase converter will run every 3 phase tool that you own (if sized appropriately). Not only that, but they aren’t really comparable to VFDs. A rotary phase converter will actually generate and balance the third leg of power for your machines so that they can smoothly run to full capacity. A VFD can be used to get a 3 phase machine started, but will let the machine run on single phase power. This means that you only get about 2/3 of the power out of your machine, and it is not likely to be balanced electrically.
For the hobbyist, a little less power and extra motor wear are not likely to be an issue because the machine is not running all day long, every day. But saying that a VFD is a good replacement for a phase converter is not exactly true because they are meant to perform different functions. The ideal situation would be using a VFD in series with a rotary phase converter. Then you get full power and speed adjustment options.
-- This is not the signature line you are looking for.
crank49
#3 posted 02-08-2015 10:47 PM
Jon, Are you talking about a static phase converter compared to a rotary phase converter?
If you are your statement is true.
But a static phase converter is nothing at all remotely similar to a VFD.
A VFD takes what ever voltage you feed it, converts it to DC, then inverts it back to AC at whatever voltage and how ever many phases and at what ever offset you want. It puts out true three phase full time power at variable hertz. By adjusting the hertz you change the speed of an induction motor if that is what you want. But the fact that it produces three phase from single phase is a fringe benefit. A VFD could even be purchased that will run any motor off DC. Just check out any of the new electric cars on the road. They all run this way.
TheGreatJon
#4 posted 02-09-2015 01:13 AM
LoL. Yep, my bad.
Economically, an RPC is still a great option if you are going to have a lot of 3 phase equipment, especially anything much over 5hp. But I think you’re right about how VFDs work. There’s a reason I went with mechanical engineering – all that mumbo jumbo with electrons gets pretty confusing…
bonesbr549
#5 posted 02-09-2015 01:22 AM
WOW, so funny the whole VFD, .vs. RPC, is still kicking huh.
crank49
#6 posted 02-09-2015 01:48 AM
That’s a good point. VFDs are not cheap, especially when you get to larger sizes. And, especially if you need a big one without using the variable speed function. But I have seen 3 hp units for less than $100.
