dw735 chip discharge
Forum topic by goochs posted 02-08-2015 03:07 PM 1200 views 0 times favorited 12 replies Add to Favorites Watch
View goochs's profile
goochs
56 posts in 1132 days
02-08-2015 03:07 PM
Topic tags/keywords: dw735 chip discharge dust control question
Looks like I will building a capture system for this beast and was wondering. Does anyone use 2 1/2 hose instead of 4” with no ill effects.
12 replies so far
View Bill White's profile
Bill White
4853 posts in 3863 days
#1 posted 02-08-2015 03:16 PM
The 735 has a fan assisted chip discharge, and throws out a BUNCH of chips. 4” will serve ya much better. I even use 4” on my 733.
Bill
-- bill@magraphics.us
View Tennessee's profile
Tennessee
2739 posts in 2417 days
#2 posted 02-08-2015 03:17 PM
I used a 2 1/2” hose on my Rigid planer with a reducer for over 10 years, sending the chips into a 15 gallon Rigid vac. Never had a problem save when the vacuum filled up, which happens way quicker than you might imagine. I would think you will generate about the same amount of chips per cut as I did.
View johnstoneb's profile
johnstoneb
2781 posts in 2075 days
#3 posted 02-08-2015 03:42 PM
Given the amount of chips a planer throws off the 4” will work much better.
-- Bruce, Boise, ID
goochs
#4 posted 02-08-2015 04:27 PM
thanks I guess I will make the trash can with a 4” input and make the vacuum side 2 1/2 inch. That will give me the best of both worlds. The output line will not be connected for the planer though, I think I will put a filter bag over the output just to capture dust that doesn’t fall to the bottom of the can.
View ChefHDAN's profile
ChefHDAN
1010 posts in 2752 days
#5 posted 02-08-2015 04:44 PM
Sometimes,If i forget to hit the remote to turn on the DC; the 735 has enough CFM all by itself to inflate the top bag of my DC through 10’ of 4” hose. You could likely just put a filter onto the output and save the electricity for the shop vac. Hehe, I’m always suprised when I shut down the planer and take off my earmuffs and realize the DC was off…again
View Crank50's profile
Crank50
173 posts in 1479 days
#6 posted 02-08-2015 04:51 PM
For a dust collector use 4” with a drop out bin as close to the planer as possible.
For 2 or 2 1/2” pipe use a shop vacuum.
If using the dust collector the pipe from the paner to the drop out bin must be as short and as smooth as possible.
View lew's profile
lew
11940 posts in 3658 days
#7 posted 02-09-2015 03:52 PM
I made one of these-
http://lumberjocks.com/topics/15116
BTW- like your avatar. Used to use the Kirby Morgan for ice diving
View pintodeluxe's profile
pintodeluxe
5565 posts in 2716 days
#8 posted 02-09-2015 04:06 PM
Many users have commented that a shop vac won’t keep up with the 735. I use a single stage 1 hp DC and it works fine.
Good luck.
View ChuckC's profile
ChuckC
827 posts in 2837 days
#9 posted 02-09-2015 04:58 PM
I’ve never tried a shop vac and I stopped turning on my DC (4” hose) too. You don’t have to. The blower in the 735 is enough.
View jmartel's profile
jmartel
7687 posts in 2052 days
#10 posted 02-09-2015 05:10 PM
I have my shop vac hooked up to the trash can I built a separator for. I don’t turn it on, and the 735’s chip blower motor is enough to still blow the top of the shop vac up enough to shoot chips and stuff out if I forget to lock it down.
View AlaskaGuy's profile
AlaskaGuy
3912 posts in 2211 days
#11 posted 02-09-2015 07:35 PM
If you could go from 4’’ to 2 1/2 ’’ and get the same results the manufacture would have built and 2 1/2’’ outlet on the machine,.
View PatrickH's profile
PatrickH
51 posts in 1790 days
#12 posted 02-09-2015 07:59 PM
My 735, seems to inflate my clear DC bag pretty well on its on. Many a time have I forgotten to turn the DC on. However, I’d look around on CL for a used DC. I picked up my old Delta for $150.
-- http://bloodsweatsawdust.com
