Packaging imprint in finish ?
Forum topic by AandCstyle posted 02-07-2015 02:56 PM 1021 views 0 times favorited 15 replies Add to Favorites Watch
View AandCstyle's profile
AandCstyle
3052 posts in 2255 days
02-07-2015 02:56 PM
I finished a box with Danish oil, rattle can spray lacquer and Johnson’s paste wax. When the recipient opened the package the packaging had imprinted in the finish. The oli cured for a week before the lacquer which dried for 24 hours before the wax and that 3 days before putting it into the box. Any suggestions on how the client can eliminate the imprint? Apply another coat of wax?
-- Art
15 replies so far
18178 posts in 1855 days
#1 posted 02-07-2015 03:03 PM
Man, that’s weird. Can they just see the imprint or feel it. If they can only see it, I would say wax it. If they can feel it, they may have to sand down a bit and either add lacquer or rewax.
View jumbojack's profile
jumbojack
1676 posts in 2622 days
#2 posted 02-07-2015 03:18 PM
Off hand I would try Naptha on a lint free cloth. Lightly wipe the affected parts with the naptha. Followed with a dry lint free rag.
Nathan will break down the wax and hopefully take the imprint. I really don’t know the effects of naptha on lacquer. You may want to test the method on a lacquered piece before trying on the box. Although at the worst you strip the box with naptha, sand back the lacquer and refinish.
Was it newsprint that transferred?
View JoeinGa's profile
JoeinGa
7736 posts in 2005 days
#3 posted 02-07-2015 03:18 PM
Would be interested in knowing HOW it happened? Maybe there was some dampness inside the box from the heat/cold exchange which causes condensation?
I’m fixing to ship a couple turned pieces that are sprayed with lacquer and I’d like to avoid this too.
AandCstyle
#4 posted 02-07-2015 03:49 PM
Bill, she can only see the imprint and only when the light is just right and is game to try re-waxing it to see if that will solve the issue.
Jack, if the waxing doesn’t work, I will try the naphtha and re-wax it myself.
Joe, I got some more details. The issue is only on two corners where the packaging was tight and the box wax left in the car for a couple hours with the Albuquerque sun shining brightly through the glass. The packaging was a soft plastic so between the heat and the pressure and the plastic/wax contact that may have been the root cause.
What does everyone else use for packaging?
-- Art
4986 posts in 2492 days
#5 posted 02-07-2015 04:13 PM
May be relevant: some plastics have “plasticizers” in them to keep them flexible and soft. It varies widely by specific plastic, but these plasticizers can do odd things to finishes if they come into contract. If you had plastic worms do odd things to the older plastic tackle boxes, it’s the same effect. I had some plastic “feet’ on a telephone leaves black circles on a store bought nightstand (years ago).....that’s how I got to looking into it.
jumbojack
#6 posted 02-07-2015 04:13 PM
So it is not ink that transformed but a surface indentation? Make sure the same kind of wax is used. The solvents vary from brand to brand.
View NoThanks's profile
NoThanks
798 posts in 1527 days
#7 posted 02-07-2015 04:43 PM
I would use denatured alcohol to clean the wax off. It won’t harm the lacquer.
Pre-cat lacquer dries hard enough to pack overnight. (You can buy pre-cat in rattle cans from Sherwin Williams)
Regular nitrocellulose lacquers take longer to cure and the off gassing can soften the topcoat back up.
I wrap things up in 1/8 foam that comes on a roll, then stretchwrap it. Then put it in a box, Next I put that box in another box filled with newspaper. Overkill, but foolproof, most of the time.
-- Because I'm gone, that's why!
View pjones46's profile
pjones46
1001 posts in 2641 days
#8 posted 02-07-2015 04:46 PM
It is defiantly caused by the excessive heat softening of the finish. It must have been like an oven in there. How about trying to rub it out and then buffing it up to the sheen as you would with a auto finish?
I don’t think your customer will be able to correct it unless they have your skill set.
-- Respectfully, Paul
AandCstyle
#9 posted 02-08-2015 01:47 AM
Here is the final report. She couldn’t find Johnson’s paste wax, so she used Mr Clean Magic Eraser (a very fine abrasive as near as I can tell), then a light coating of vegetable oil wiped dry. If she is happy, I am happy, but I’m not sure why she asked my opinion, then did her own thing. :D
Anyhow, thanks to everyone for the responses, I definitely learned some valuable lessons.
-- Art
pjones46
#10 posted 02-08-2015 01:52 AM
Art,
Thanks for the update good to know.
pj
#11 posted 02-08-2015 02:12 AM
As long as she’s happy. I’ve thought about magic erasers for that kind of use before. May try it sometime when the need arises.
View Grumpymike's profile
Grumpymike
2238 posts in 2314 days
#12 posted 02-08-2015 06:01 PM
Hi Art
Sorry to chime in so late, but I’ve been in the shop and haven’t checked the e-mails or the computer for a couple of days.
Had the same thing happen to a box I sent to my daughter … After some head scratching, I told her to go to one of the big box stores and pick up some MinWax finishing was and a piece of #0000 steel wool and give it a good rubbing and then polish with a clean cloth … wholla! problem solved!
It seems that there is some bubble wrap that reacts with the wax. My thought is that the carnuba (sp) oils react with some plastics.
But I am glad that your customer was happy in the end.
-- Grumpy old guy, and lookin' good Doin' it. ... Surprise Az.
AandCstyle
#13 posted 02-09-2015 01:03 AM
Thanks everyone. I won’t be using plastic again. I will go with foam as suggested by Iwud.
-- Art
View changeoffocus's profile
changeoffocus
467 posts in 1616 days
#14 posted 02-09-2015 01:28 AM
Art
“but I’m not sure why she asked my opinion, then did her own thing”
My guess is your customer spends a lot of time on this site and just did what a lot of others do.
AandCstyle
#15 posted 02-09-2015 01:42 AM
Bob, I’m just happy that it worked to her satisfaction. :D
-- Art
