QSWO on curved piece
Forum topic by CharlesA posted 02-07-2015 03:14 AM 884 views 0 times favorited 4 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3305 posts in 1706 days
02-07-2015 03:14 AM
I’m designing a piece that has curved legs. I know that some folks, when making legs out of QSWO, glue a 1/8” thick layer on the sides to give the QS look on all four sides. How would you do this with a leg that is curved?
View pintodeluxe's profile
pintodeluxe
5568 posts in 2721 days
#1 posted 02-07-2015 03:29 AM
I wouldn’t worry about veneers on curved legs. Just select some nice rift sawn stock, and it will look great.
View ElChe's profile
ElChe
630 posts in 1244 days
#2 posted 02-07-2015 02:42 PM
If it is a modest contour, a quadrilinear router bit may get you there. If it is a more pronounced curve then i can’t think of a way to have all sides of the leg be quarter sawn unless you use a thin veneer. my suggestion is to use quarter sawn sides on front and back or most visible orientation or use rift sawn oak as suggested above. good luck.
17572 posts in 1765 days
#3 posted 02-07-2015 02:51 PM
Do they curve in two directions or just one. If just one I’m thinking to have the actual qs on the curved sides and veneer on the flat side. Glue it on oversized and trim with a flush trim bit.
CharlesA
#4 posted 02-07-2015 03:14 PM
Thanks for all the help. Let me elaborate a bit, and maybe that will help clarify a bit more. I am working on a baptismal font for our church. All the furnishings are in flat sawn oak. I’m not the biggest fan of flat sawn oak, but it needs to cohere with the rest, so I thought maybe doing it out of QSO would be a good option. However, my inspiration for design has curved legs, so that is what got me to wondering about this.
I’m not copying this design, but using it as a starting place. This font is sapele veneer, I believe (see the continuous grain on the lower cross piece and leg). I’m trying to avoid busy grain on this piece. I’d appreciate any thoughts you might have.
