| Forum topic by frankzen | posted 220 days ago | 410 views | 0 times favorited | 17 replies | ![]() |
220 days ago |
Topic tags/keywords: drop leaf butter fly repairs basswood refurbishing First message here—- I am restoring an old (not antique) drop-leaf butterly table. One of the drop leaves is missing a 5 inch sliver of material on its square edge. The piece missing is about 3/8 of an inch wide at its widest…and it tapers down to almost nothing. I tried wood filler first but gave up quickly. Any ideas on how I can match what’s missing ?? Thanks -- --I belong to too many forums -- |
220 days ago |
Hi Frank, Hang out a while and you will get some more suggestions also. |
220 days ago |
Here’s a look at what I am faced with : http://i7.photobucket.com/albums/y256/Charleszen/damage.jpg Hope that works! -- --I belong to too many forums -- |
220 days ago |
If that is one of the leaves, would be possible to see a pic of the other one to have a more clear idea? W e l c o m e to LumberJocks! -- Francisco Luna, San Francisco Bay Area. |
220 days ago |
Hmmm, |
220 days ago |
Couple more pics to make it more clear: http://i7.photobucket.com/albums/y256/Charleszen/dsc00068.jpg That should do it . -- --I belong to too many forums -- |
220 days ago |
I would do what bentlyj advise… -- Francisco Luna, San Francisco Bay Area. |
219 days ago |
If that table was brought to me by a client I would suggest the following repair. -- If a man says something in the forest and there's no woman to hear it, is he still wrong? |
219 days ago |
I’ve done a number of table repairs over the past few years, both for myself and for paying customers. bentlyj and donbee are correct in their approach. With out the broken piece, you are going to have to build that area back up so it will hold up to use in the future. By carefully cutting away the damaged area down that edge of the table and replacing it with a solid wood strip, you create a joint that is as strong as the rest of the table. Once that is done, you can use dyes to blend the new wood to match the existing wood. Once the color is right, I would use a good quality gloss polyurethane. I use Gloss because there are no fillers in it that tone down the gloss. If the customer wants a more subdued finish, you can always rub down a gloss to a semi gloss or satin finish, you can’t polish up a satin finish to a gloss, because of those fillers. -- Greg - Charles Town, WV |
219 days ago |
The only thing I would add to the good advice already given, is to keep scrap pieces of the wood you will be using to repair the edge and experiment with the dyes and finishes before actually applying them to the repair. Dalec |
219 days ago |
Well I guess we have a consensus. Good suggestions all. And I guess I have got a couple of hours of work ahead of me. Thanks to all for helping out this amateur!! I’ll post pics when it’s all done. p.s Donbee—love your sig ! -- --I belong to too many forums -- |
219 days ago |
Another option might be to just trim 1/4 to 3/8 inch off that leaf. |
219 days ago |
If you can find a match ofr the original bead a cove on the table you should consider taking a few hairs off the bead side as it was obviously binding by the look of the screws holes and the stress crack. Good luck Bob -- A mind, like a home, is furnished by its owner |
219 days ago |
I agree with the replace a piece idea. If I were cutting off a piece, I’d use a fine tooth hand saw or plywood blade on a table saw to cut off a tapered piece to keep chip out to a minimum or put some masking tape over the area you saw, & then run the table piece through a jointer to get a good clean glue joint edge. Good luck. -SST -- Accuracy is not in your power tool, it's in you |
219 days ago |
Bob #2 – Good idea. I was wondering what caused that crack and now it’s obvious the leaf was binding somewhere. There is a steel pin on top of one of the butterflys that is missing on the other one…thats the one that supported the leaf with the missing piece. Incidentally the table came to me with one leaf off and two hinges missing. I found the EXACT match on-line at a place called Horton Brasses. Great people there..efficient as all get out. -- --I belong to too many forums -- |
206 days ago |
OK I’m back after a week or so of mostly handwork. I first cut the damaged area off being VERY careful not to split or splinter anything. I then ourchased an 8 foot length of oak cove molding…cut it to fit the length and started working it to blend in. A lot of sanding…then when it was finished, filling with a colored wood filler and more sanding. http://i7.photobucket.com/albums/y256/Charleszen/dsc00072.jpg http://i7.photobucket.com/albums/y256/Charleszen/dsc00069.jpg If you’ve forgotten what it looked like before: http://i7.photobucket.com/albums/y256/Charleszen/damage.jpg Now all that remains is even more sanding, and the finishing. Had to do a couple of other minor repairs..such as replacing a one inch length of dowel which the butterflys rotate on. But the end is coming. Thanks to all for suggestions…I’m sure I’ll be back – I have a number of projects planned. -- --I belong to too many forums -- |
206 days ago |
Looks good well done. In the past I’ve just cut a piece of of both sides and rerouted the ruled edges -- Jim from Heirloom Woodshop, custom furniture ,maker, woodworking school, heirloomwoodshop.com |
197 days ago |
Got it finished finally—- still have to make some minor adjustments on the hinge positions to close up the gap at one end of oneof the leaves…but I’m taking a break right now! Here’s some pics: The finish is Cabernet stain with 3 coats of gloss poly…I’ll rub it down to satin later. That’s it for now. -- --I belong to too many forums -- |
| Forum | Topics |
Woodworking Skill Share
2928 |
3961 |
258 |
955 |
226 |
Woodworking Trade & Swap
623 |
Coffee Lounge
2398 |
LumberJocks.com Site Feedback
524 |
