Help with Drill Press
Forum topic by groland posted 04-22-2009 11:31 PM 880 views 0 times favorited 2 replies Add to Favorites Watch
View groland's profile
groland
183 posts in 3436 days
04-22-2009 11:31 PM
I just purchased an old used drill press. The collars that hold the bed and drilling head to the upright shaft are of a type with which I am not familiar.
A hex bolt passes through the collars and is tightened to hold the collars in place. These bolts pass through cylindrical parts ground flat on the insides to connect with the upright. It is these cylindrical parts that contact the upright to grip it when the bolts are tightened.
In attempting to break the tool down into sections to carry it upstairs, I found that these cylindrical grippers were somewhat frozen to the upright. I had to knock them out with a woodblock and hammer—clearly not a useful method of loosening then to move the adjustment collars. These parts were well cleaned by the fellow who sold me the D.P. They are free of rust, pitting and other evidence of corrosion.
So my question is, what can I do to ensure that these collars do not freeze up again, and that I can keep them easy to adjust? Should I oil them, grease them, put on a coat of wax, what?
Thanks,
George
2 replies so far
View marcb's profile
marcb
768 posts in 3698 days
#1 posted 04-23-2009 01:44 AM
Probably have oil on them and it turned to “varnish” oil ages badly and gets all gummy.
I would just wax them, I have a similar system and don’t really have any issues.
View PurpLev's profile
PurpLev
8536 posts in 3673 days
#2 posted 04-23-2009 01:58 AM
wax it, don’t oil it…. plus, I wouldn’t worry about it, these are supposed to stay stationary anyways (unless I think you refer to something else), and in the event that you REALLY have to take them apart – a wooden/rubber mallet does the trick.
