DW735X Planer Stand and Separator
Forum topic by DBordello posted 02-06-2015 06:15 PM 2183 views 0 times favorited 23 replies Add to Favorites Watch
View DBordello's profile
DBordello
132 posts in 1195 days
02-06-2015 06:15 PM
Topic tags/keywords: planer
I fired up my DW735X planer for the first time yesterday. I plopped it on the workbench (heavy), and grabbed a garbage bag and zip ties for “dust collection”. As you can imagine, there were no chips in the garbage bag when I was done, and plenty in the shop. So, my planer needs a stand, and a chip separator.
I was original inspired by the cart built by John Heisz. However, it appears that this did not work terribly well, and he has since moved on. Therefore, I have been following the design by someone with a similar problem. His design is inspired by the Rockler Dust Separator
I am looking for feedback on my current plans. It is comprised of two chambers, with drawers (not shown) at hte bottom. The goal of the first chamber is to separate the chips from the air. There will be a screen (not shown) between the two chambers. The second chamber is for fines, and hopefully there isn’t much deposited in here. My dimensions can be found here .
23 replies so far
View sawdustjunkie's profile
sawdustjunkie
382 posts in 1686 days
#1 posted 02-06-2015 06:55 PM
The reason you didn’t have any chips it the bag, is you can’t use a plastic bag. If you were to use an old pillow case, it would work just fine. Air has to be able to pass thru the bag!
Either that or just punch some holes in the plastic bag for the air to escape. Otherwise, you are just blowing up a baloon with the blower fan.
I have my 735 hooked up to my dust collector and don’t get any chips on the floor.
-- Steve: Franklin, WI
DBordello
#2 posted 02-06-2015 06:57 PM
The reason you didn t have any chips it the bag, is you can t use a plastic bag. If you were to use an old pillow case, it would work just fine. Air has to be able to pass thru the bag!
I have my 735 hooked up to my dust collector and don t get any chips on the floor.
- sawdustjunkie
I was aware it was an awful plan. However, it was a quick hack to try the thing out. Now, on to something better.
View baldguy's profile
baldguy
18 posts in 1342 days
#3 posted 02-06-2015 07:09 PM
I’m the guy he referred to via the reddit post. I suppose I should upload those pics as a project here on LJ at some point :).
I also wanted a cart that would allow me to operate the planer without a dust collector. partly because my dust collector is currently disassembled, but also because even once I return the DC to service, my shop layout doesn’t allow for a permanent drop for the planer.
DBordello – it looks like with your current design you might run into a problem I had – taking too much air from the primary chamber from too close to the dust bin results in a lot of scrubbing. the baffle I finally came up with has about a 3/4”x15” slot at the top to allow a lot of air in that way, and it doesn’t extend all the way down to the chip bin. I’m not sure how much scrubbing I still have, but that seems to have significantly limited it.
View ChuckC's profile
ChuckC
828 posts in 2904 days
#4 posted 02-06-2015 07:22 PM
Maybe I’m just not getting it but that looks like it’s going to be a pain to empty and clean.
When I got my 735 I didn’t have a DC either. I did something similar to this and it sucked. Then I used a (breathable) bag that came with my leaf vacuum and that worked well. I have since purchased a proper DC and that works the best.
baldguy
#5 posted 02-06-2015 07:32 PM
well on mine, I just open the front door, pull out the rubbermaid bin, and dump it. easy as pie. with DBordello’s design (and the rockler one) there are drawers to do the same thing.
View JoeinGa's profile
JoeinGa
7735 posts in 1976 days
#6 posted 02-06-2015 07:36 PM
Here’s what I ended up with.
http://lumberjocks.com/topics/43997
View jmartel's profile
jmartel
7812 posts in 2119 days
#7 posted 02-06-2015 07:46 PM
I made a Thein baffle for a garbage can. Works mostly well enough. I still need to wear a respirator and clean up after, but it catches most of the shavings.
sawdustjunkie
#8 posted 02-06-2015 07:49 PM
Awhile back, Jay Bates had his planer hooked up to a PVC pipe that emptied into a pillow case. He said it worked great. Since you said your dust collector isn’t working, use the bag from it and just use a big zip tie to connect it to the planer.
baldguy
#9 posted 02-06-2015 08:02 PM
I think you were referring to my comment about my DC – my dust collector works fine, it’s just disassembled… and I already built my cart anyway. the cart works extremely well without a dust collector and keeps the footprint much smaller than an external trashcan would. this is DBordello’s post, though. he’s trying to solve a similar problem.
View ElChe's profile
ElChe
630 posts in 1305 days
#10 posted 02-06-2015 08:41 PM
JoeinGA, that cardboard box is hilariously awesome. Who woulda thunk it. You did. And it works. Well played and well done. Gotta go get me some cardboard boxes to see what I can do to top your dust collection. Unfortunately my cat owns most of my cardboard boxes at the moment and she’s MEAN. :)
DBordello
#11 posted 02-06-2015 08:44 PM
DBordello – it looks like with your current design you might run into a problem I had – taking too much air from the primary chamber from too close to the dust bin results in a lot of scrubbing. the baffle I finally came up with has about a 3/4”x15” slot at the top to allow a lot of air in that way, and it doesn t extend all the way down to the chip bin. I m not sure how much scrubbing I still have, but that seems to have significantly limited it.
- baldguy
I am looking at your pictures, and I am not sure I see where you are talking about. The “plan”, is that the air will come in, go down the ramp, drop the chips off (yeah, right), then back up the primary chamber, into the “chip box”, and in to the secondary chamber. I realize that it is hard to figure it out from the drawings.
Thoughts to improve it?
DBordello
#12 posted 02-06-2015 08:44 PM
Maybe I m just not getting it but that looks like it s going to be a pain to empty and clean.
When I got my 735 I didn t have a DC either. I did something similar to this and it sucked. Then I used a (breathable) bag that came with my leaf vacuum and that worked well. I have since purchased a proper DC and that works the best.
- ChuckC
The bag isn’t an awful idea. However, I am hoping I can make a nice stand with DC as well.
DBordello
#13 posted 02-06-2015 08:45 PM
Here s what I ended up with.
- JoeinGa
Is the box still for sale?
JoeinGa
#14 posted 02-06-2015 08:50 PM
Funny! Wish I had taken a video when that thing blew out on me!
And sorry, the box was used when we moved from Tennessee to here.
Oh yeah, WELCOME to LJs
ChuckC
#15 posted 02-06-2015 10:42 PM
- ChuckC
The bag isn t an awful idea. However, I am hoping I can make a nice stand with DC as well.
- DBordello
When I had the leaf bag setup I put the bag underneath in the stand I made for the planer. It was concealed. Now that I don’t use the bag I use the space for storage.
