| Forum topic by Betsy | posted 217 days ago | 605 views | 1 time favorited | 12 replies | ![]() |
217 days ago |
OK – I know this has been covered but I can’t find it. So the first question is about how to search the site. I wanted to find a post about adjusting the fence on a crosscut sled. I tried a number of different words to search but nothing came up. How would you search for something like this? The more important question is adjusting the fence on my new crosscut sled. First – I know my squares are, in fact, square. I also know for a fact that the test material is flat and square and my blade is square to the table at 90 degrees. I’ve cut a number of test strips and my cut is off just a hair. In fact, you can only see a very tiny amount of light between the square and the end of the board. I’m trying to decide how I should adjust the sled to eliminate the little sliver of light. So if you are placing the square on the right side of the board and the light is on the left end – do you move the fence forward or backward? Thanks in advance for your help. -- You can't get a hug from Facebook. |
