| Forum topic by Geologist | posted 221 days ago | 1160 views | 0 times favorited | 26 replies | ![]() |
221 days ago |
Topic tags/keywords: block plane hand plane cheap plane cheap block plane Hello, I’m just starting out in woodworking and am slowly acquiring more tools as soon as my paychecks come in. And one thing I’ve noticed is that I really could use a good block plane. I purchased a cheap one off of ebay thinking I had gotten a good deal, turns out not to be the case. So 25 bucks down the drain already. I cant really afford a Lie Nelson or a Veritas plane, although I drool about them daily. And ever since the first failure, I’m reluctant to go out and buy a cheapie, being unsure of its quality. So if any of ya’ll have any suggestions, or maybe even a good reliable plane for sale, I would be glad to hear your advice! Cheers. Edit 4/22: http://www.flickr.com/photos/37691378@N04/3466388281/ |
221 days ago |
Any Stanley plane will be a good start. The trick with a cheap plane is to sharpen it more often. They often use softer grade steel, or lower quality. Keep that blade sharp, and you’ll do fine for a few years, until you can afford an upgrade. Most of the local home centers got cheapies. if you get a good cheap one not a cheap cheap one. check it out, make sure it’s rugged, and built well. find one with a good blade lock, some are cheap and the blade will move on you when you use it. -- Woodshop supplies at bulk discounts. www.getneds.com |
221 days ago |
Keep your eye at craigslist….with lots of people unemployed, many are selling everything trying to survive the situation…..last week, I saw a Lie NIelsen BP like new there and bought it for $70!!! ($165+tax new) It’s particular to me, that a Block Plane , as small it is, is one of the planes more affected in performance by its quality construction. -- Francisco Luna, San Francisco Bay Area. |
221 days ago |
What was wrong with the first plane you bought? |
221 days ago |
I guess that could be the case, me not knowing what I’m doing. And it probably is the case since I’m new to it. I have watched several videos on how to tune a plane, and I thought I was at least decent with sharpening, but what do I know. I guess what I really need is for someone to show me what I’m doing wrong…. Hmm…If only I knew someone in this field of expertise. Thanks for the advice everyone! |
221 days ago |
To address your most recent post there might be a lumberjock nearby who would be willing to help in person. However, I’ll leave the revelation of your location entirely up to you…. -- Chris |
221 days ago |
I bought several planes on eBay that I’ve been happy with. I took a hand tool class at Woodcraft that helped me a lot with regard to sharpening my chisels and planes and using them properly. I would recommend it. There are a ton of resources on the internet to guide you towards the right plane if you’re looking at older stuff. Restoring them to working condition is a lot of fun, too. -- Jim |
220 days ago |
Before giving up on the $25 block plane, what are the symptoms you’re getting that keeps it from functioning properly? Someone here might have some ideas to make it work. If it’s really a basket case from the get-go, it’d be a service to others to tells us the brand and model if it’s a new plane. I’m getting good service from a couple of older reasonably priced planes…a Craftsman 9-1/2, a Record 09-1/2, a Record 060-1/2, and a Stanley 220. The end performance is usually determined by setup and sharpening. |
220 days ago |
I use old Stanley’s and Records exclusively. Just buy Garrett Hack’s handplane book and it tells you how to tune old planes up so they work better than new. Good Luck. -- -JimmyC...Clayton,NC- "Just smile and wave boys, smile and wave" |
220 days ago |
I’m with knotscott on this one – before going and spending any more money on another block plane that will give you the same performance (I can almost guarantee you that…) why dont you share with us what’s wrong with your current one? what are the symptoms? whats wrong with it? we can help you tune it, or at least give you some ideas. I’m still using my stanley BP that I got from Lowes for $19.95. it works SUPER GREAT!!!!! (sure it’s a bit heavier and bulkier than LN/LV, but for $20, and my current needs, is more than plenty). my point is that even the lower cost planes can prove to be a great tool , if tuned properly. Heres another great tool I recommend for you: The Handplane Book -- When in doubt - There is no doubt - Go the safer route. |
220 days ago |
I’m in the show us some photos of what you got camp. Hopefully, we can get the value of your $25 back. -- We must guard our enthusiasm as we would our life - James Krenov |
220 days ago |
Most of the old and often called cheap handplanes will work just fine ONCE you really learn how to tune and sharpen them. I’m pretty new to handplanes myself. I had my father’s old Stanley #5 that would even scrape up sawdust. I had tried to use it a few times over the years but mostly it sat on a shelf for over 20 years. I finally got the bug and deciede to learn how to use it. I read and watched everything I could get my hands on about sharpening and tuning a plane. I tackeled the #5 with mixed results at first. While it was better it was still difficult to use. I re-read and re-watched the tuning stuff again. I paid closer attention and worked on the #5 some more. This time I think I got it right. It will shave a see through shaving from red oak the full width of the blade. The sole is true and slick and it works like a dream. Since then I have purchased 6 more “cheap” planes from eBay and spent the time to true them up. Every one of them now works as well as the #5. Most of these purchased planes are Stanleys that were sorely in need of attention. One was purchased for only $5 and $4.95 shipping. That was for a Stanley Bailey #3. I believe this one may turn out to be my favorite plane. I believe that most can be made to work unless it is broken or has some type of mechanical problem. Like everything else in woodworking, you have to keep at it until you are satisfied with the results. Good luck. |
220 days ago |
If you were looking for a $70 dollar option…. http://www.woodcraft.com/product.aspx?ProductID=149381&FamilyID=21170 -- We must guard our enthusiasm as we would our life - James Krenov |
220 days ago |
I posted an update on the plane, and pics can be found on the links. It looks like a sharp plane and it is very heavy. I believe after reading all of your posts that this plane can be made into an awesome plane, I just, at the moment don’t yet have the experience to do so. Although, I just purchased the book all of you suggested and I should receive within a week! Thank you all for taking some of your time to help me out!!!!! Cheers. Oh, one more thing, if you have any extra time, I posted another thread with some questions on my first woodworking project!!! So if you would be so kind to check it out and offer any possible advice you may have to help me along! |
220 days ago |
looks like a good one… no need to go anywhere and spend anything to get anything else….. yet. from the sound of it (the problem you described) it’s not a matter of unsharpened blade – the front throat opening, should be as small as you’d like the shavings thickness to be. if you want thin shavings – leave only ~1/32” opening in the throat (yours has an adjustable toe- thats a nice thing to have). leaving the throat too wide allows the blade to dig into the wood too deep, causing large chunks of wood to break off, and the plane to chatter. either way – worth mentioning , make sure your blade is not sharp – but super sharp, there are many good tutorials on here and on the web how to accomplish that – aim for mirror finish on the blade, both back, and beveled edge. -- When in doubt - There is no doubt - Go the safer route. |
220 days ago |
Thanks PurpLev! I feel kinda relieved about not having to spend more money on a slightly better plane! I’ll definitely give that a try tomorrow! Someday I look forward to purchasing a LN or Veritas, but before that there are many other tools for my monies to go too. If anyone else thinks of something I should try I look forward on reading your comments! I’ve only been on this website for 2 weeks and I have already learned sooo much. |
220 days ago |
Do many of you LJs have experience with Woodriver planes? How do they compare to other planes (both cheapies and pricies)? |
220 days ago |
Geologist…. -- Francisco Luna, San Francisco Bay Area. |
219 days ago |
Your plane looks a lot like a Simmonds that a friend of mine has….which is really pretty well made compared to the Chinese and India made alternatives. He loves it. The body is cast in Sheffield England, the blade is from North Carolina, the brass parts are from Rockford, Il, and it’s assembled in Maryland. Like PurpLev suggests, once there’s a bevel, just get it super sharp by honing it. The biggest error I used to make was trying to take off too much wood with each pass….you want to take off just a smidge. |
219 days ago |
I agree that your plane looks fine and would go back to the suggestion to buy one or both of the books listed above. They are excellent. To make it work, you need to be able to sharpen the blade, tune the plane, set up the plane and use the correct technique (e.g. skew the plane). I have a blog where I was collecting reference materials related to hand planes. Might be of interest. http://lumberjocks.com/WayneC/blog/series/43 Another good book is Making and Mastering Wood planes. There is good information in this book on how to tune a block plane like yours and techniques for useing planes (in addition to how to make one) There are also a number of videos available on the topic. I’m running out of time to post links, but you can find them in my blog link above. -- We must guard our enthusiasm as we would our life - James Krenov |
219 days ago |
Thanks for the tips LJs! I am currently in the process of trying them out right now. And so far I see improvement but nothing promising. I am still getting some chattering on the face grain side of the board. On the edge grain I am finally getting some good thin sheets planed off. Mind you I’m trying this on a pine board and so the wood is really soft. I tried planing some on the end grain of a red oak board and got poor results from that. Probably due to the blade not being sharp enough. I’ll keep trying and researching and trying again. Thanks!! |
219 days ago |
Are you planing with the grain? -- We must guard our enthusiasm as we would our life - James Krenov |
219 days ago |
Good call Wayne, I was wondering that myself. It’s a adjustable block plane, used for end grain. |
219 days ago |
if you get poor results from end grain – your blade is probably not sharp enough! do some research, there are plenty of good resources around for that – again – aim for mirror shine finish on the blade, to the point where you are afraid to touch it! slicing end grain with a sharp blade (even if not in the plane yet…) should result in smooth shiny cut surface if your blade is sharpened properly. as far as chattering on the face frame – you might also have been planing against the grain… try reversing direction. think of the grain as waves in the ocean, and your plane as a surfboard… you wanna surf the wave, not go against it. -- When in doubt - There is no doubt - Go the safer route. |
219 days ago |
Woodchuck1957, you can use a Low Angle ~ Adjustable Block plane everywhere, along the grain, end grain, smoothing sharp edges, chanfering, as a spokeshave to make round shapes, sharp your pencil…..Pretty much a Swiss Army Knife! -- Francisco Luna, San Francisco Bay Area. |
219 days ago |
I’m in agreement about the versatility of the low angle block plane. I would suggest sticking to edge grain until your consistently getting see-though shavings. Then move to the face of the board. End grain requires specific techniques. e.g. getting endgrain wet, knocking down edges before plaining, etc. -- We must guard our enthusiasm as we would our life - James Krenov |
160 days ago |
I had a similar problem with a cheap plane I bought – the problem is; the planes are not tuned up when you get them. Flatten the bottom of the plane, clean all the swarf and paint from the moving parts, apply a drop of oil (light machine) to any moving parts and of course set and sharpen the blade. After I did this, the plane started to cut properly and I could get very thin, even shavings. Do not expect to get the same performance as a Veritas or Lie Nielsen – but you should get more than acceptable results. If the plane is a little hard to push along the board, try applying a little candle wax (natural wax if possible) to the sole of the plane (a few stripes only), this will make the plane glide effortlessly across the wood, repeat as necessary. -- Tony - All things are possible, just some things are more difficult than others! - SKYPE: Heron2005 (http://www.poydatjatuolit.fi) |
| Forum | Topics |
Woodworking Skill Share
2928 |
3961 |
257 |
955 |
226 |
Woodworking Trade & Swap
622 |
Coffee Lounge
2398 |
LumberJocks.com Site Feedback
524 |
