Incra Ultra Lite Jig clamping
Forum topic by panofish posted 04-21-2009 07:21 AM 2612 views 1 time favorited 6 replies Add to Favorites Watch
View panofish's profile
panofish
36 posts in 4101 days
04-21-2009 07:21 AM
I bought an incra ultra lite jig and I’m curious what you guys think about how I should clamp it to my table. I explain more detail in a video clip on my blog…
http://panofish.net/2009-04-20IncraJig
-- Alan Lilly, http://www.panofish.net
View Gary's profile
Gary
9386 posts in 3675 days
#1 posted 04-21-2009 03:04 PM
Personally, I think you have the best solution, using another T slot.
View odie's profile
odie
1691 posts in 4082 days
#2 posted 04-21-2009 03:42 PM
I would drill down through the table and use a handle with a built in bolt and a “T”-nut underneath. I have done something similar to my tables. I would add a little epoxy on the “T”-nuts so stay in the table. The “T”-track is also a great idea.
That’s a great looking blog you have. Are you sure you want to brave it out here? This your second post in almost two years.
View jollygreen445's profile
jollygreen445
1 post in 3353 days
#3 posted 04-28-2011 08:30 AM
To me, it looks like turning the router table end for end having the curent “T” slot between the insert and the saw table would solve your problem. You would be able also to leave the Incra Jig set up, as it would not be in the way as often placed on out board end of the table…... I bought an Incra Jig but as yet have not set it up…
panofish
#4 posted 04-28-2011 03:43 PM
Here is the actual solution I implemented…
http://www.panofish.net/incra-jig/
View ClayandNancy's profile
ClayandNancy
520 posts in 3257 days
#5 posted 04-28-2011 04:24 PM
That’s a great solution, might be on the large size but with 4 magnets over that span must hold pretty good. Nice job.
View rance's profile
rance
4267 posts in 3402 days
#6 posted 04-28-2011 06:03 PM
One of the best fence solutions I’ve seen on a TS mounted router when you have the room. Very nicely done. The other hidden fact is that your Incra fence ‘could’ be reversed to work with the TS too. This could be the next contender for SOS.
