What do you use for adjustable workbench feet?
Forum topic by Dan658 posted 02-05-2015 10:06 PM 9670 views 0 times favorited 13 replies Add to Favorites Watch
View Dan658's profile
Dan658
93 posts in 1505 days
02-05-2015 10:06 PM
I’m planning on building a new workbench soon and I’ve decided to do adjustable feet since my basement isn’t very flat and I want to make sure it is exactly the same height as my table saw. The standard home center ones seem too weak, so what have you come up with? Did you make some or buy heavy duty feet?
This is all I’ve found so far. It seems simple and sturdy.
13 replies so far
View johnstoneb's profile
johnstoneb
3070 posts in 2408 days
#1 posted 02-05-2015 10:08 PM
I just use a wede shaped piece of wood shoved under one or two legs.
-- Bruce, Boise, ID
View WhyMe's profile
WhyMe
1080 posts in 1796 days
#2 posted 02-05-2015 10:27 PM
That’s a good idea using the bolts. You can add a second nut to lock the bolt to keep it tight at the adjusted height.
View sawdustjunkie's profile
sawdustjunkie
399 posts in 1952 days
#3 posted 02-05-2015 11:58 PM
I bought some heavy duty feet at my local hardware store.
They have a 2 1/2” wide base to them.
I think they were about $3 each or it may have been 2 for $3.
Ace Hardware or a big True Valye store.
-- Steve: Franklin, WI
View TheFridge's profile
TheFridge
10814 posts in 1721 days
#4 posted 02-06-2015 12:37 AM
3/8” all thread, with one nut set in like you have it and another to lock it.
View NoThanks's profile
NoThanks
798 posts in 1764 days
#5 posted 02-06-2015 03:15 PM
I use the bracket with the threaded hole for the bolt.
Just drill a hole into the bottom of the leg for the bolt to go into.
I could have put a lock nut on it, but it doesn’t move.
-- Because I'm gone, that's why!
View mtnwalton's profile
mtnwalton
42 posts in 1261 days
#6 posted 08-08-2015 01:04 AM
I’m using Kreg double lock casters with 1/2” adjusting bolts on a multi purpose table I’m building. So far they look like they’ll work great. I’m a big believer in everything mobile.
View CharleyL's profile
CharleyL
223 posts in 3599 days
#7 posted 08-08-2015 02:36 AM
I use pinball machine feet. They are available from The Pinball Resource www.pbresource.com for less than $1.00 each. They are a very well made coaster type foot that handles an uneven floor well with a 5/16 or 3/8 bolt about 2 1/2” long to thread into the bottom of the leg. A standard hex nut can be used for locking them at any length. A T nut or most any kind of threaded insert of the correct size in the bottom of the leg will accept them.
Each foot will handle about 500 lb.
Charley
View SirIrb's profile
SirIrb
1239 posts in 1466 days
#8 posted 08-08-2015 12:30 PM
Similar to what you did but the bolt went through the board and i have a cinching nut on the other side of the board.
CharleyL
#9 posted 08-08-2015 01:20 PM
Sarah,
What more can I add? Look at the feet on a pinball machine. Then imagine putting it on a wooden leg. You need to drill a clearance hole up into the leg, then install a threaded insert. There are only 2 bolt sizes of these 3/8 and 5/16. You choose which size you want when you get to order them. The pad part is the same size (from memory) about 1 3/4 diameter and only the bolt size is different. To install the foot, add a hex nut to the threaded part of the foot and run it all the way down to the foot by hand. Then the foot, with the nut already screwed on, gets threaded up into the insert in the bottom end of the leg. The excess length of the bolt is why you need the deep clearance hole. Screw the foot in until it is about 3/4” from the bottom of the thread and the hex nut. Install the rest of the feet in their legs the same way. Then place the table, machine, or whatever in it’s final position. Put a level on the top of the machine or table and then unscrew the feet until all feet sit firmly on the floor and the level shows that the top is level in all directions. Then use a wrench to turn the hex nuts up to the insert in the bottom of the legs and tighten them to lock the foot at that height setting. Done.
If you ever move the machine/bench/table to a new position, do the same leveling and adjustment steps again.
I’ve used these feet on my scroll saws, my Unisaw out feed table, my work benches, etc. None have ever failed. A cheap and very workable solution.
Charley
View KayBee's profile
KayBee
1083 posts in 3481 days
#10 posted 08-08-2015 06:48 PM
I’m using hockey pucks and bolts for leveling feet. Not done yet, but this is what they will look like.
-- Karen - a little bit of stupid goes a long way
View jedc43's profile
jedc43
1 post in 4034 days
#11 posted 08-28-2015 07:34 PM
I m using hockey pucks and bolts for leveling feet. Not done yet, but this is what they will look like.
Thats a awesome idea… but I think it would work alot better with Bruins Pucks… :)
- KayBee
View Murdock's profile
Murdock
131 posts in 2719 days
#12 posted 08-28-2015 07:48 PM
I used these for two benches
http://www.rockler.com/combination-leg-equalizer
I did replace the mounting plates with heavier duty t-nuts that I purchased at a hardware store.
Obviously not as thick as the ones shown above using the bolts, but I haven’t had any issues. Both benches are Fir legs with a double thickness of 3/4” plywood for tops. 6’ long, not sure how much they weigh, but I do have the shelf loaded down with tools.
I do like the hockey puck idea though
-- "Anyone who has never made a mistake has never tried anything new." - Albert Einstein
View MrRon's profile
MrRon
5261 posts in 3478 days
#13 posted 08-28-2015 09:52 PM
Put a large fender washer between the nut and the wood leg.
