Guide bushings that get loose... remedy?
Forum topic by Jofa posted 02-05-2015 03:30 PM 835 views 0 times favorited 6 replies Add to Favorites Watch
View Jofa's profile
Jofa
272 posts in 1740 days
02-05-2015 03:30 PM
I’ve been using these HF brass guide bushings for a couple of projects and they’re great. They work beautifully when using spiral bits and a jig.
However, I need to tighten the collet every so often, I assume because of the vibration of the router.
I purchased additional base plates for my router so I pretty much have one dedicated to the bushing I use the most. Aside from simply crazy-gluing the collet, is there any other way to keep it secure? I was also thinking Locktite.
-- Thank you Lord for the passion and ability to make things from your creation.
View Stoli's profile
Stoli
57 posts in 3269 days
#1 posted 02-05-2015 03:33 PM
Go to the box store and find a rubber oring that fits over the threads. My whiteside inlay kit came with one, and I have copied the idea to my other bushings.
View Jofa's profile
Jofa
#2 posted 02-05-2015 03:35 PM
Thanks Stoli. Very good suggestion.
View JesseTutt's profile
JesseTutt
853 posts in 2013 days
#3 posted 02-05-2015 03:38 PM
In defining “thread” there is a tolerance that defines a small gap between the bolt’s thread and the nut’s thread. Perhaps HF increased that gap.
Epoxy, Locktight, crazy-glue, etc.. tend to be of a more perminite nature. If you want to change bushings you would have problems removing the old size bushing.
I would try to close the gap with a wrap or two of tape, like what a plumber does with iron pipe. This would help fill in the gap and yet allow you to remove the bushing.
View DocSavage45's profile
DocSavage45
8450 posts in 2745 days
#4 posted 02-05-2015 04:36 PM
Teflon tape? Cheap solution, and removable.
-- Cau Haus Designs, Thomas J. Tieffenbacher
View Redoak49's profile
Redoak49
3075 posts in 1891 days
#5 posted 02-06-2015 12:07 AM
I used to have this problem and use a spring washer made for this problem. Several places including MLCS sell them for about $6 for two.
4872 posts in 2395 days
#6 posted 02-06-2015 12:16 PM
The teflon tape works well, as does the O ring. I also have a bushing nut that has locking screws built in. I think it came with something, maybe The Dado Wiz tool. You can buy them, but they are the more expensive way to solve the problem.
