Made a mess of my cast iron....
Forum topic by jacquesr posted 02-05-2015 03:26 AM 1971 views 0 times favorited 45 replies Add to Favorites Watch
View jacquesr's profile
jacquesr
339 posts in 1324 days
02-05-2015 03:26 AM
Hi…
Need to turn to you guys to figure out what I can do to fix my mess…
Here is how the story goes…
Got my Laguna 14 Twelve a week ago.
Decided to use Bostik GlideCote…. great result. Very happy.
Now on to my Delta 36-725. I see some stain, some very light rust since I never treated it since I got it 6 months ago.
Read about Evapo Rust… Bought the product, made some little “pounds” with Playdoh… Dropped the liquid…
Left for an hour…. a mess.
I used a stainless steel cleaner to try to make thing less messy… at least it’s all smooth now.
But nasty looking…
Have a good laugh at my picture…
Now, what an honest man to do with it?
Thanks in advance.
Jacques
45 replies so far
View crank49's profile
crank49
4029 posts in 2872 days
#1 posted 02-05-2015 03:50 AM
WD-40, steel wool, bunch of elbow grease.
jacquesr
#2 posted 02-05-2015 03:56 AM
Thanks – any idea if I can bring it back completely?
View TheFridge's profile
TheFridge
8838 posts in 1388 days
#3 posted 02-05-2015 04:11 AM
I’d just use mineral spirits and wax it. But you should see my saw.
jacquesr
#4 posted 02-05-2015 04:25 AM
I would rather see your fridge….
View Lumberpunk's profile
Lumberpunk
334 posts in 2238 days
#5 posted 02-05-2015 04:35 AM
scotch brite pad + 3 in 1 oil +1 elbow grease
-- If someone tells you you have enough tools and don't need any more, stop talking to them, you don't need that kind of negativity in your life.
jacquesr
#6 posted 02-05-2015 04:40 AM
any way to use my ROS to speed things up…?
View Rick_M's profile
Rick_M
11077 posts in 2282 days
#7 posted 02-05-2015 04:43 AM
The trick is to wait 10 years then not worry about it anymore :O
If you can’t wait that long then search for “Ronald Walters cast iron” on youtube.
-- http://thewoodknack.blogspot.com/
View tomd's profile
tomd
2125 posts in 3672 days
#8 posted 02-05-2015 05:00 AM
WD 40 and ROS with a 150 or 180 disc, wax after.
-- Tom D
View BurlyBob's profile
BurlyBob
5229 posts in 2167 days
#9 posted 02-05-2015 05:23 AM
rubbing compound- terry cloth- ROS
View bobasaurus's profile
bobasaurus
3376 posts in 3086 days
#10 posted 02-05-2015 07:40 AM
Fine abrasive “rust eraser” block? I’d avoid ROS sanding in case you put a dent in the flat grind.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View AlanBienlein's profile
AlanBienlein
159 posts in 2576 days
#11 posted 02-05-2015 10:49 AM
If you can t wait that long then search for “Ronald Walters cast iron” on youtube.
- Rick M.
^^^^This^^^^
View ScottKaye's profile
ScottKaye
573 posts in 1854 days
#12 posted 02-05-2015 11:03 AM
- jacquesr
Sure,
I have done the exact same thing. Go out and buy a pack of green scotch bright pads (big box store has them in the paint isle near the sandpaper) and cut them to the diameter of your ROS then attach them to ROS (assuming you have a hook and loop set up) You can use wd-40 as a solvent or a even a an automotive rubbing compound.
Scott
-- "Nothing happens until you build it"
View kaerlighedsbamsen's profile
kaerlighedsbamsen
1239 posts in 1615 days
#13 posted 02-05-2015 11:13 AM
Is it still flat? If yes then no problem- its a tool.
-- "Do or Do not. There is no try." - Yoda
View ChefHDAN's profile
ChefHDAN
1010 posts in 2751 days
#14 posted 02-05-2015 12:50 PM
WAX it and make sawdust!!!
View Sparks8286's profile
Sparks8286
72 posts in 1391 days
#15 posted 02-05-2015 01:10 PM
There’s only one thing you can do with it now. Sell it to me for $50. It’s obviously junked.
Seriously though, I’d start with some steel wool. Don’t rub it on it. Try rolling it under your fingers on a small section first. See if you can get it to pull the stain up without ruining the finish on the top (I assume you want to preserve that without getting a whole bunch of scratch marks all over it).
-- If you can't fix it with a hammer, you have an electrical problem.
showing 1 through 15 of 45 replies
