Thin Stock 1/8" thru 5/8"
Forum topic by parkerdude posted 12-14-2014 02:45 PM 3518 views 0 times favorited 16 replies Add to Favorites Watch
View parkerdude's profile
parkerdude
182 posts in 3320 days
12-14-2014 02:45 PM
Topic tags/keywords: question
Hi Guys,
I see all these beautiful jewelry and keepsake boxes and I want to make some. Where do you find, or how do you make, solid / hardwood stock from 1/8” to 5/8” thick.
I’ve tried local suppliers and cabinet makers around town and zip, nada. I know that you don’t need much at a time. Is there an outlet for a variety of thin wood stock or someone that specializes in it?
Thanks,
-- dust control
16 replies so far
View NY_Rocking_Chairs's profile
NY_Rocking_Chairs
508 posts in 3466 days
#1 posted 04-20-2009 11:09 PM
Resawing on a band saw is the most common way to get it.
-- Rich, anybody want a peanut?
View alan coon's profile
alan coon
115 posts in 3582 days
#2 posted 04-21-2009 12:41 AM
Woodworkers source,and free shiping
-- Al, South E. Az., But it's a dry heat.
View johnpoolesc's profile
johnpoolesc
246 posts in 3229 days
#3 posted 04-21-2009 12:47 AM
most of the time i use my planner to get thinner stock.. if it’s 4 quarter or better you can resaw. buying stock that thin is a costly. lowes locally sells red oak in thin stock BUT the price is stupid.. you can find some on ebay at times
-- It's not a sickness, i can stop buying tools anytime.
View Dan Lyke's profile
Dan Lyke
1519 posts in 3994 days
#4 posted 04-21-2009 06:25 AM
This is gonna sound really weird, but I just recently used my Festool circular saw on a rail to rip/resaw three 1½ by 1/8” strips from ¾ thick stock. I actually ripped to about 3/16” and planed the last 1/16” off because my jig and rail weren’t as long as my strip, so I had to reposition in the middle of the rip.
If i can do that with a circular saw, you can probably do it with a tablesaw. The circular saw only has a max 2” depth, and both a circular saw and a table saw have a huge kerf relative to a bandsaw, but it is possible.
View Rob's profile
Rob
143 posts in 3799 days
#5 posted 04-21-2009 09:55 AM
Dan,
That doesn’t surprise me at all. I use my Festool TS75 Plunge saw to cut 1mm x 1mm strips for stringing. For making boxes, though, I’d cut close to the desired width with a band saw, then plane/thickness down to the the desired size.
Regards,
Rob
-- http://www.damnfinefurniture.com
Craftsman on the lake
2726 posts in 3307 days
#6 posted 04-21-2009 01:52 PM
Hate to say it but Home depot has thin stock poplar, oak, and maple, in 2’-4’ lengths about 4” wide. It’s usually in pocket racks near their other select wood.
View Gary's profile
Gary
9262 posts in 3302 days
#7 posted 04-21-2009 02:51 PM
To help everyone know how to help, maybe you could list the tools you have that could be used for such work.
Dan Lyke
#8 posted 04-21-2009 02:53 PM
Daniel, yeah, you can buy the stock from HD, but it’s usually pretty plain. If I’m going to spend time building a box I want interesting grain and book matching (or at least as much as one can get with a 2.5mm kerf blade…).
Barry, yeah, I’ve had me a few pieces explode.
View Julian's profile
Julian
880 posts in 3394 days
#9 posted 04-21-2009 03:05 PM
Parkerdude, we don’t buy the stock that thick. We cut it down with bandsaws or in a pinch you can use a tablesaw.
-- Julian, Park Forest, IL
parkerdude
#10 posted 04-21-2009 04:30 PM
Thanks guys. You’re right Gary, I should have told you all what tools I have. My problem is that the only power tools that I have are a table mounted router and an old radial arm saw. I do most of my work with hand tools.
I don’t have the money now to buy a band saw. I was hoping to find a source where I could buy thin stock.
-- dust control
View PurpLev's profile
PurpLev
8534 posts in 3517 days
#11 posted 04-21-2009 04:54 PM
since jewelery boxed aren’t that large, you could also resaw your thicker stock with a handsaw, sure it takes some practice, but with an aid of a fixture to keep your saw inline this is very doable., and the saw kerf is thinner than a table/circular saw, so you won’t lose much materials. look into a japanese ryoba pull saw for this.
View Albert's profile
Albert
497 posts in 3458 days
#12 posted 04-21-2009 05:28 PM
Try these people, very nice guys and easy to talk to. they supply thin stock specifically for making Shaker Oval Boxes, but I doubt they would object to your using the wood for other square boxes.
http://www.shakerovalbox.com/
parkerdude
#13 posted 05-11-2009 09:38 PM
PurpLev,
Since your last post I have in fact tried re-sawing 4/4 and 3/4 oak about 4” – 8” wide and up to 2 feet long and then hand planing to flat. I’m using a japanese pull saw, and I’m glad for the two handed handle. It is a fair amount of work and takes me about an hour to re-saw and plane about 120 sq. in.
It does make me more careful with planning and use.
Not for everyday use, but not as bad as I thought.
Thanks for your suggestion.
-- dust control
PurpLev
#14 posted 05-11-2009 09:51 PM
cool, glad it works for you, and glad I could have helped.
as others have stated bowsaws are also a good tool for that purpose. they might give you a faster cut because of their mechanics – I’ve just never used one myself, so I recommended what I knew that would work. 8” x 24” is quite a large board to resaw though – touche!
View LesB's profile
LesB
1437 posts in 3312 days
#15 posted 05-12-2009 08:10 AM
If you don’t have any local hard wood suppliers you may have to go with mail order. Also some cabinet or other wood working shops will resaw (or plane) thicker stock at a reasonable price.
-- Les B, Oregon
