Cutting plywood with a circular saw
Forum topic by BossHog posted 475 days ago 440 views 0 times favorited 13 replies Add to Favorites
View BossHog's profile
BossHog
4 posts in 475 days
475 days ago
Topic tags/keywords: plywood cutting circular saw
I cut 3/4” plywood with a circular saw on a big special knockdown table because I lack the room for a panel saw. I was using a 6.5” Black & Decker Woodhawk that I have had for 10 or so years. It was clearly underpowered but would labor through the 3/4” plywood eventually. I bought a Porter-Cable 7.5” 325MAG saw, installed a brand-new Dewalt plywood blade, and proceeded to try to cut some 3/4” plywood (some sanded plywood from Lowe’s) with it. From the first few inches, the saw blade smoked and the wood smoked and burned. The saw labored through the cut ( 48”) but left the wood burned on both sides of the cut and the sawblade black. I then switched to another brand-new Dewalt plywood blade and tried the next cut. After about 12”, I gave up because the wood and sawblade were still burning. I took out the old Woodhawk with an old plywood blade and finished my work, slowly but surely without burning either the wood or the sawblade. The plywood was adequately supported for the cutting. The brand repair center said nothing was wrong with the saw itself, but the second blade had warped due to overheating.
Is this result typical of what I can expect from a 7.5” saw cutting plywood? If so, what size circular saw do I need to cut plywood safely without burning? I have a table saw but I can’t safely cut a 4’ x 8’ sheet on that by myself, which is my usual mode of operation.
-- Boss Hog
View Buckskin's profile
Buckskin
483 posts in 516 days
475 days ago
I have a Skill Clasic and it seems to work just fine on saw horses and all. Heck I have even cut cultured limestone with it.
13165 posts in 928 days
475 days ago
Was the saw blade mounted correctly. Teeth pointing the correct way.
BossHog
4 posts in 475 days
475 days ago
Yes, I checked that and the repair shop agreed.
-- Boss Hog
View edp's profile
edp
102 posts in 488 days
475 days ago
Don’t know without seeing the saw but it sounds like the arbor is/was misaligned with the shoe. That is, assuming you were using a straight edge to guide the saw. Can’t blame the plywood if your smaller saw worked fine.
Ed
-- Come on in, the beer is cold and the wood is dry. www.crookedlittletree.com
View oscorner's profile
oscorner
4573 posts in 839 days
475 days ago
I know you said you had a new plywood cutting blade on it, but what brand was it? You may want to use a multipurpose blade and see if that makes a difference. I know that the plywood cutting blade should work without smoking and burning. Any good circular saw should cut the plywood without what you have experienced. If you continue using you saw with this abuse, I’m affraid that you risk getting hurt or at the least, burning up your saw motor.
-- Jesus is Lord!
dennis mitchell
3033 posts in 842 days
475 days ago
Different type blade…
View markrules's profile
markrules
134 posts in 643 days
474 days ago
Take it back and try another of the same model. May be something in the saw not working correctly. I’d also guess that the blade is on backwards… If not, I’d look at the tool.
View Thos. Angle's profile
Thos. Angle
3409 posts in 490 days
474 days ago
We use a Skil worm drive with Freud blades. I can’t remember the number of the blade but it never bogs down even in 1 1/2 ” Alder or Oak. I think the problem is your blades. The saw should cut the ply like butter. I had ply blade cut a crooked line in a sheet of plywood one time. When I took it out it looked like a potato chip. I’ve never used a plywood blade since. If you are worried about tear out use masking tape and for sure use a straight edge.
View Dan Lyke's profile
Dan Lyke
402 posts in 653 days
474 days ago
Sounds like you may also have problems with torquing the blade, so you’re getting plywood in contact with the side of the blade rather than just the teeth.
It’s not a function of saw power, it’s a function of the blade generating heat, and how it’s dissipating heat. So either the blade isn’t big enough and you’re not radiating enough energy (which is possible, but I doubt it if you’re having that problem in a foot of cutting), or there’s something in your technique with the blade that’s causing the side of the blade to rub on the wood, heating far more than the teeth of the blade would.
I had similar problems with a low-end saw whenever I tried to cut along a straight-edge. I now have a Festool TS55 circular saw that runs on a rail, and have had no problems with blade alignment relative to the guide, and can rip two-by wet fir with no problems.
BossHog
4 posts in 475 days
474 days ago
The blade was a Dewalt plywood blade. It was installed properly, even the repair shop said that. I’m going to try a conventional blade and see how that works. Switching to a plywood blade helped wen I was using the small saw, but maybe a conventional blade will work better on the larger saw. If that doesn’t work, I’m going to buy one of the Festtool saws. I received the saw as a gift and I didn’t save the box, which I need to return the saw, so I’m stuck with it.
Thanks for all of your insights into this problem.
-- Boss Hog
View hardwired56's profile
hardwired56
1 post in 474 days
474 days ago
For what it’s worth, I had the same problem with a 18v battery saw with a plywood blade from DeWalt. The saw just smoked and literally burned the wood before killing the battery. I took the darn things apart and discovered the blade had been incorrectly stamped at the factory. Look at the teeth and rotation of the saw motor with out a blade attached. Try flipping the blade. I got a 325 MAG and had ZERO trouble with it, just sorry imported blades from China.
View Wooder's profile
Wooder
163 posts in 714 days
474 days ago
I use the same blade with my Milwaukee in 3/4 hickory ply. Melts thru it like butter. Blade or saw problem.
Jimmy
-- Jimmy
View snowdog's profile
snowdog
674 posts in 510 days
472 days ago
This is probably self evident but I wanted to post it anyway. When you cut any wood the saw blade should barely extend past the wood being cut. I like 1/8 to 1/4 so that more teeth are in contact with the wood at any given time during the cut.
Bookmark And Share This Page
