Fluorescent wiring confusion
Forum topic by TheLastDeadMouse posted 02-04-2015 03:09 AM 934 views 0 times favorited 6 replies Add to Favorites Watch
View TheLastDeadMouse's profile
TheLastDeadMouse
38 posts in 1399 days
02-04-2015 03:09 AM
Topic tags/keywords: electric electrical wiring lights fluorescent
Quick background, the total of my electrical experience is replacing a couple kitchen fixtures, greenhouse fans, and a college electrical circuits class 8 years ago.
I had a 8ft T12 fluorescent light with a ballast that went bad, so I decided to just replace it with a new 8ft T8 fixture since the ballast and the new fixture were about the same price. I took the old fixture down and got more than I bargained for with the wiring.
The light is controlled by two switches, but its not a typical three way switch, both switches have to be on for the lights to turn on. There’s an additional 3 fixtures that run off the same switches. Taking the old fixture down, there’s a an orange and a black wire leading to the next fixture in line, then two strands of 12/2 and one 14/2 coming from the attic. None are marked.
I’ve never wired anything where I couldn’t just go white to white and black to black, but there’s more going on here than I’ve ever encountered before. Any help on how to proceed?
View TheFridge's profile
TheFridge
9606 posts in 1509 days
#1 posted 02-04-2015 03:17 AM
Find a local electrician and give him a 12 pack to fix it.
View HerbC's profile
HerbC
1763 posts in 2883 days
#2 posted 02-04-2015 06:11 AM
+1 get a qualified electrician, 12 pack payment may not be an option but pay the person to fix it right…
I used to be an electrician but I just pull my own wire now…
Good Luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
TopamaxSurvivor
18285 posts in 3699 days
#3 posted 02-04-2015 06:36 AM
Sounds like you have had a home owner who knew just enough to be a hazard modifying your wiring at some point in the past. You need a professional opinion on all of the wiring in the house! Good luck.
TheLastDeadMouse
#4 posted 02-04-2015 02:35 PM
I bought the house from the son of the contractor who built it as his own home in the 70’s. There’s a lot of examples of “Good enough for my house” taken literally. Stuff that works but not the way its normally done. This seems to be no exception. I had planned on getting an electrician for a few other things around the place, so this will get added to the list.
View Frank Doyle's profile
Frank Doyle
42 posts in 3420 days
#5 posted 02-04-2015 03:34 PM
If you want I could talk you through it over the phone, it is very easy takes ten min. 774.364.3066
-- Frank
TopamaxSurvivor
#6 posted 02-05-2015 05:04 AM
I bought the house from the son of the contractor who built it as his own home in the 70 s. There s a lot of examples of “Good enough for my house” taken literally. Stuff that works but not the way its normally done.
- TheLastDeadMouse
I was warned when I was an apprentice about all carpenters thinking they are electricians ;-))
