Finish for Baby Crib
Forum topic by MrRon posted 02-03-2015 09:05 PM 784 views 0 times favorited 5 replies Add to Favorites Watch
View MrRon's profile
MrRon
4710 posts in 3207 days
02-03-2015 09:05 PM
Topic tags/keywords: question
I need to finish a baby crib I made from pine. Is there any finish I should be concerned about using due to it being for a baby?
I was thinking about; first a wash coat of shellac, followed by light sanding; second, 2 coats of an oil base stain and third a satin coat of polyurethane varnish.
5 replies so far
View HornedWoodwork's profile
HornedWoodwork
222 posts in 1178 days
#1 posted 02-03-2015 10:54 PM
Outside of oil based polyurethane you should be fine with most finishes. Does the crib have a plastic cover for teething rails? if not, those are a great addition and can both protect the wood from the child and the child from the wood. When I made the one for my kids I used shellac and wipe on poly.
-- Talent, brilliance, and humility are my virtues.
View Hammerthumb's profile
Hammerthumb
2836 posts in 1939 days
#2 posted 02-03-2015 11:07 PM
I would be a little leary of oil based stains as some might have some form of metallic driers. Same goes for BLO. Safest would be shellac as a finish with water based dyes for color.
-- Paul, Las Vegas
View fivecodys's profile
fivecodys
973 posts in 1600 days
#3 posted 02-03-2015 11:59 PM
I had to make a few cages for a guy who breeds and sells Reptiles.
He needed a finish that could be ‘Chewed” by these critters.
The best I could find locally was Varathyne water based poly.
It’s been 8 years and so far so good.
google “Baby Safe Finishes”. There are quite a few companies out there.
-- There' are two theories to arguin' with a woman. Neither one works.
View Jake's profile
Jake
850 posts in 1594 days
#4 posted 02-04-2015 11:56 AM
I mulled that question over many times when thinking about my baby crib project. The consensus seemed to be, that once fully cured most finishes are safe to gnaw on for a bit.
In the end though, I opted to play it safe and go to nature, so I am going with amber shellac on my oak crib. You can’t beat a product that is used to coat pills with. That has to be food safe.
-- Measure twice, cut once, cut again for good measure.
MrRon
#5 posted 02-04-2015 06:07 PM
Thank you for your input. Finishing is not one of my strong areas. I figure a baby cradle will only be used for a year before going to something bigger.
