| Forum topic by Joker9125 | posted 222 days ago | 296 views | 0 times favorited | 5 replies | ![]() |
222 days ago |
221 days ago |
OK Joker, if this is a joke question, here is an answer. Buy a square PVC tube that the outside is larger than 1/2 inch by 1/2 inch inside. -- Ron in Osseo, Minnesota |
221 days ago |
Not a joke and maybe I need to re-word my question. I need the inside diameter to be exactly 1/2 inch by 1/2 inch. A few millimeters to large is ok, but that’s all the margin of error I can afford. |
220 days ago |
Try US plastics, they sell square extruded acrylic tubing, the 3/4” OD gives you an 5/8” ID since the wall thickness is 1/16”. If you give them a call they might be able to find something closer to what you are looking for. -- Rich, WNY, www.nyrockingchairs.com |
219 days ago |
thanks for the help! |
217 days ago |
Also try McMaster-Carr. www.mcmaster.com. This site is SUPER easy to use and order from (This site should be the template for any wholesale supplier’s website…really good!) and they will have the stock you are after. Shipping is reasonable and quick. Search for PVC and the options will appear before you…:) Good Luck. -- If, in your life, you attain the means to help; you incur the responsibility to act. |
| Forum | Topics |
Woodworking Skill Share
2917 |
3944 |
256 |
950 |
224 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2391 |
LumberJocks.com Site Feedback
524 |
