Saw Filing help needed
« back to Hand Tools forum
Forum topic by fumehappy posted 02-03-2015 06:40 PM 773 views 0 times favorited 3 replies Add to Favorites Watch
View fumehappy's profile
137 posts in 2184 days
02-03-2015 06:40 PM
Hoping someone can help me with this…
I filed and set a Disston D-8 crosscut 8tpi yesterday. 15 degrees rack, 20 degrees fleam. Teeth points are all nice and sharp, as well as slightly set.
It followed the line with no guiding when I made a cut down a piece of 5/4 pine, but I found the cut was really ragged and even though it followed the line, it was extremely course… almost as rough as a chainsaw. Did I do something wrong? Did a 10 TPI Atkins and it came out great. Cut was smooth and square.
3 replies so far
View chrisstef's profile
17251 posts in 2938 days
#1 posted 02-03-2015 06:42 PM
Try running a stone lightly down the sides of the teeth, flush with the plate. You may have some burrs on the edge of the teeth from filing. At least that’s my thought.
View DrDirt's profile
4421 posts in 3674 days
#2 posted 02-03-2015 07:18 PM
+1 Chrisstef
you need to flush the teeth and that will level the set. Sometimes a burr, or perhaps a tooth or two that got set a little deeper than the rest.
#3 posted 02-03-2015 07:52 PM
Ah, I shall try that then. I know that it can correct set problems, but I didn’t realize it would effect the quality of the cut as well.
