Melamine Cabinet Sides to Wood Face Frame
Forum topic by dhg posted 04-19-2009 01:15 AM 4567 views 0 times favorited 5 replies Add to Favorites Watch
View dhg's profile
dhg
197 posts in 3713 days
04-19-2009 01:15 AM
Topic tags/keywords: question
I’ve got about 20 kitchen and bathroom cabinets to build for a customer and at first the boxes were going to be 1/2” cherry plywood with 3/4” cherry face frames. Great no problem, then he told me it would be 3/4” plywood, he got a good deal on the plywood. (He’s supplying the material) Well when I went to pick up the plywood, it turned out to be 3/4” cherry melamine.
My problem now is how would be the best way to attach the melamine sides to the cherry face frames. Normally I would dado the sides 1/4” into the FF and white glue and staple the sides to the FF. Now I’m thinking a 3/8” deep dado and using a urathane construction adhesive and stapling to the face frames but I’m worried that the melamine will blow out and chip. my experience with melamine has pretty much been just shelves.
Any other ideas or suggestions?
Thanks, Rich
-- Talent on Loan from God - Rush Limbaugh ----------www.genesiswoodworks.com----------
5 replies so far
View kolwdwrkr's profile
kolwdwrkr
2821 posts in 3591 days
#1 posted 04-19-2009 03:54 AM
dhg, couldn’t you use pocket screws where not visible, and then just glue and clamps where they would be, like finished ends. You don’t really even need to screw or nail the face frame to the box. The glue is more then enough to hold a frame on the box. You can use the screws in place of clamps. If you don’t have a pocket screw jig you could just clamp it, or if you feel there is a lack of strength, use biscuits. Running the grooves seems like time well waisted.
View childress's profile
childress
841 posts in 3542 days
#2 posted 04-19-2009 07:20 AM
just like kol said….I always use pocket screws. Works perfectly fine in melamine ans it’s alot faster than doing it the way you are thinking.
-- Childress Woodworks
View ND2ELK's profile
ND2ELK
13495 posts in 3774 days
#3 posted 04-19-2009 02:34 PM
I have always just glued my face frames on. You could shoot a few brads equally spaced to hold the frames in place till glue dries and it also allows you to pull the clamps a little quicker.
God Bless
tom
-- Mc Bridge Cabinets, Iowa
View dhg's profile
dhg
#4 posted 04-20-2009 03:10 PM
Thanks for the input guys, I have both pocket screws and biscuits which I use often. I think i’ll go with the some pocket screws.
View Peter Oxley's profile
Peter Oxley
1426 posts in 3875 days
#5 posted 04-20-2009 04:17 PM
Pocket screws here, too. I use dowels instead of screws whenever the screw pockets might be visible (end of run cabinets, etc). Biscuits would work fine instead of dowels.
-- http://www.peteroxley.com/woodworking -- http://north40studios.etsy.com --
