Blade alignment question
Forum topic by tyson posted 04-18-2009 08:52 PM 1020 views 0 times favorited 4 replies Add to Favorites Watch
View tyson's profile
tyson
43 posts in 3529 days
04-18-2009 08:52 PM
i am trying to true up my table saw, i just purchased a new blade a freud combination 50 tooth.the blade is also chrome plated. i marked a “favorite tooth” with liquid paper and when i run the dial indicator on that tooth front and back im geting a reading thats out .001” wich i think is prety good, but when i run the dial across the side of the blade it gains .005” near the center. is this normal? am i doing it wrong? i would apreciate your info before i put the saw back together as i nearly had to scrap the thing to get at the bolts.
thanks in advance
Tyson
-- a truly wise man never plays leap frog with a unicorn
tyson
#1 posted 04-18-2009 09:19 PM
well thanks Pat, i guess i’m going to put it back together now, hope all is straight and true.
View TomHintz's profile
TomHintz
207 posts in 3542 days
#2 posted 04-19-2009 10:42 AM
I have noticed many blades “growing” at the center by several thousandths. I think this comes from coatings they apply and how they “work” the blade body to stiffen and straighten them. I have never had a problem with a blade that showed this thicker center so would not worry about it.
-- Tom Hintz, www.newwoodworker.com
View CharleyL's profile
CharleyL
223 posts in 3509 days
#3 posted 04-19-2009 07:16 PM
OK, the blade is true. How about the fence and the miter slots? Are they parallel with the blade front and back? Is the blade at a true 90 deg to the table? When set at 45 is it a true 45? As long as you are calibrating you might as well check everything.
CharleyL
tyson
#4 posted 04-20-2009 02:06 AM
i have, i used the miter slots to set the blade with a dial indacator, checked both miter slots. adjusted the 90 deg and 45. the fence adjusts real easy like the byesmeyer type. saw’s running great!
Thanks for the tips guys
much apreciated
Tyson
