Shearing bits vs spiral bits for edge jointing
Forum topic by Sirgreggins posted 02-03-2015 04:25 PM 874 views 0 times favorited 3 replies Add to Favorites Watch
View Sirgreggins's profile
Sirgreggins
299 posts in 2263 days
02-03-2015 04:25 PM
Hey guys, A friend of mine is looking to get into woodworking and I was going through the basics of router bits the other day with him and he asked why one would use a shearing bit vs a spiral bit when edge jointing on the router table. I told him I didn’t think there would be much difference in the cut on the edge and that the helical blade slices the wood leaving a cleaner cut. Is there any reason to use one over the other in that situation?
VS.
3 replies so far
View TheFridge's profile
TheFridge
9608 posts in 1514 days
#1 posted 02-03-2015 05:10 PM
don’t think it matters that much. I haven’t use the spiral but I’ve never seen that tearout was a problem with them when they come out the grain. Unless one of them can produce a completely finished edge, it’s not gonna matter to me.
View pintodeluxe's profile
pintodeluxe
5706 posts in 2841 days
#2 posted 02-03-2015 05:57 PM
The spiral bits have more angle to the cutters. They work great. A 1/4” spiral bit is so versatile for plunge cuts, mortises, and trimming. If you don’t need a large diameter bit, they are pretty inexpensive too.
I have some shearing bits, and they work fine. They cut more like straight bits (ie: pretty good cuts with occasional small chipout).
View Gene Howe's profile
Gene Howe
10543 posts in 3456 days
#3 posted 02-03-2015 06:03 PM
Here is a solid carbide end mill. 1/2” with a cutting length of 2”.
Pretty pricey, though. But, I’ll bet it would do the trick.
