Adhesive Question??
Forum topic by saw4fun posted 225 days ago 232 views 0 times favorited 4 replies Add to Favorites Watch
View saw4fun's profile
saw4fun
61 posts in 239 days
225 days ago
I have a project in the planning stage that I am unfamiliar with the “logistics”, but would really like to do. It involves Black Walnut, Honeylocust, and Stainless Steel rods. I still have to figure some weights to decide how big or small of rod I will need. My question is,, what would you guys recommend for an adhesive to secure the stainless steel and the wood together? The stainless steel will basically be acting as partially exposed dowels, and “stretchers” from the legs to the feet. Thanks in advance.
-- There is no such thing as scrap wood! Rastus NE www.nativelumber.net
View Gene Howe's profile
Gene Howe
334 posts in 328 days
225 days ago
If I understand, the dowel will extend from the “bottom” of the leg into a foot. So there won’t be any lateral stress, right?
In that case, I’d epoxy both ends. Maybe make your holes a 32nd larger than the dowel.
What distance will the dowel span? That would make a difference in how far up into the leg you’d want to drill.
-- Gene
View Kindlingmaker's profile
Kindlingmaker
1479 posts in 426 days
225 days ago
Epoxy sounds right and don’t forget to heavily score the metal. Another adhesive that is rarely used in woodworking but works well is Silicon and priming the metal with a silicon primer gives the best results.
saw4fun
224 days ago
Thanks guys. It will have some lateral stress but the holes are going to be 3-4” and 8” deep so I don’t think it will be a problem. fingers crossed!
View HallTree's profile
HallTree
2041 posts in 667 days
224 days ago
Checkout this web site
-- Ron in Osseo, Minnesota
