Most useful combination square or double square size?
« back to Hand Tools forum
Forum topic by diito posted 02-03-2015 08:04 AM 5475 views 0 times favorited 14 replies Add to Favorites Watch
View diito's profile
diito
30 posts in 1791 days
02-03-2015 08:04 AM
In my user collection of squares I have a new 12” Starrett combination square, an old ~1920’s but still accurate 12” Starrett I think my great grandfather might have taken home from his job at Ford (it’s etched on the blade, with a number), and a similar aged Stanley Sweetheart 6” solid square that’s also still accurate.
The 12” combination square is great for most things but sometimes it’s a little too big. I don’t end up using the 6” square too much. I think I need a smaller combination square or double square. What do you guys find to be the most useful as far as size, the 4” or 6”? Is there any reasons to get a double square vs. a combination square? I can’t see any advantage to the double square but maybe I’m missing something?
14 replies so far
View ksSlim's profile
ksSlim
1290 posts in 3089 days
#1 posted 02-03-2015 11:25 AM
I use both a 12” and a 6” Starrett combo and a 3” double.
Double is nice for smaller pieces.
-- Sawdust and shavings are therapeutic
View unbob's profile
unbob
810 posts in 2102 days
#2 posted 02-03-2015 03:38 PM
I like the Starrett 4” combo, another in this photo is a 6” flat square.
View willie's profile
willie
534 posts in 2653 days
#3 posted 02-03-2015 03:51 PM
I use both combination and double squares in 4”,6”,12”, and 24”. I use the 4” more than the rest, I do a lot of small projects. Although I don’t need the 24” often, it’s nice to have when needed. If I had to choose between a combination or double head, I’d go with the combo. I also have multiples of each so once I have one set I don’t have keep changing them.
-- Every day above ground is a good day!!!
View JayT's profile
JayT
5960 posts in 2410 days
#4 posted 02-03-2015 04:05 PM
I use the 12” the most, but also get a lot of use out of a little 4” Starrett double square.
View Richard H's profile
Richard H
489 posts in 1879 days
#5 posted 02-03-2015 04:29 PM
I had a 4” Veritas double square and used it as my go to square until I dropped it and broke the pin that holds the blade in place. I have been living without it since and really do miss the thing. I might go with a Starrett double square of the same size when I get around to replacing it probably once the weather warms up a bit but there is nothing wrong with the Veritas version either.
Now I mostly use a 6” combination square. The thing is ok but it’s a lot bulkier than the double square even though it’s really not that big. I do find the combination head on the 6” isn’t that useful to me as if I need a 45 degree angle I often need the reach of the 12” one anyways. I hardly ever use my 12” combination square as I just don’t need something that big most of the time.
So I guess in order of use I would say for my work. 4” double square, 6” double square, 12” combination square. at which point I might be tempted to just ditch the 4” double square and go with a 6” double square instead. Now that I type this maybe I’ll put off replacing my broken 4” square and get a 6” double square instead.
Hope that helps.
View brtech's profile
brtech
1052 posts in 3121 days
#6 posted 02-03-2015 05:01 PM
The most used square in my shop is the 4” Veritas double square. It’s in my apron pocket or in my hand all the time. I have a 6” fixed square from Woodpeckers that I reach for a lot, but my 12” Starrett combo square is always close at hand.
View bondogaposis's profile (online now)
bondogaposis
5088 posts in 2550 days
#7 posted 02-03-2015 05:05 PM
I use a 4” double square constantly it is always in my shop apron. I don’t know how I got along without it. I think it is the perfect size for most things.
-- Bondo Gaposis
View MrRon's profile
MrRon
5192 posts in 3442 days
#8 posted 02-03-2015 06:02 PM
I use my Starrett square to check the accuracy of my other squares, modifying them if needed. I keep the Starrett safely in a toolbox and use the other squares for woodworking. A 12” Stanley combination square is the most used in my shop.
View ChefHDAN's profile (online now)
ChefHDAN
1172 posts in 3048 days
#9 posted 02-03-2015 09:57 PM
I’ve got 2 4” starrett double squares that I use all the time, and only go get the 12” off it’s hook on the pegboard when I need a longer line.
View HornedWoodwork's profile
HornedWoodwork
222 posts in 1413 days
#10 posted 02-03-2015 10:50 PM
6” for me. I have three and I set them for different measurements on the project and keep them set for future use. Occasionally I use my 12” but it is pretty rare.
-- Talent, brilliance, and humility are my virtues.
View AandCstyle's profile
AandCstyle
3178 posts in 2456 days
#11 posted 02-04-2015 12:52 AM
- Richard Hillius
Richard, I bet if you call LV and ask about a replacement pin, they will send you a new one gratis.
I almost never use use my Starrett combination square since I got a 4” Veritas double square, but I have been working on smaller projects.
-- Art
View Ghidrah's profile
Ghidrah
667 posts in 1421 days
#12 posted 02-04-2015 01:15 AM
For framing I use a 12” combo or speed square, when I’m in my shop I use a 6 and 12” machinist square for marking and a 6” combo along with a marking gauge for mortise, tenon, and shoulder cuts.
-- I meant to do that!
diito
#13 posted 02-04-2015 05:37 AM
It seems the 4” double square is really popular. Any reason why you guys are using that over a 4” combination square? The 45 degree reference face on the combination square head seems like it’s worth a few extra bucks to have. I’ve never owned a double square though so maybe it gets in the way somehow?
View PatrickH's profile
PatrickH
51 posts in 2086 days
#14 posted 02-08-2015 05:21 PM
I love my 4” double and 12” combo. They pair very well together. I do wish I had one of the tiny engineer squares for checking tails with narrow pin sockets.
-- http://bloodsweatsawdust.com
