Sketchup question
Forum topic by Mark posted 02-03-2015 04:56 AM 800 views 0 times favorited 9 replies Add to Favorites Watch
View Mark's profile
Mark
906 posts in 1944 days
02-03-2015 04:56 AM
I’m in the middle of drawing up a hutch and buffet in Sketchup. I started out making every thing a component. Some where down the line I exploded every thing to make modifications to the various pieces. Of coarse now I cant move anything as almost nothing is a component. I have to be able to move the pieces to attach measurements to them. Is there a solution to this or am I screwed?
Thanks in advance.
-- Mark
9 replies so far
View MT_Stringer's profile
MT_Stringer
3160 posts in 3200 days
#1 posted 02-03-2015 05:24 AM
It’s a little late, but I saw Jay make a copy of a component, pull it out in the open, make changes, then delete the copy. It works.
View jerryminer's profile
jerryminer
917 posts in 1411 days
#2 posted 02-03-2015 05:34 AM
I think you have to go through and re-identify your parts as components.
What I would do is make a copy of the model (move/copy), select a part, move/copy to an empty spot and see how “clean” it is, then clean it up by erasing extra geometry and make it a component. Then move it back into the model. Do this with every part. Then you will be able to “hide” parts as you need, and erase the leftovers.
If you only need to pull measurements, you can do that in x-ray mode
View JAAune's profile
JAAune
1788 posts in 2286 days
#3 posted 02-03-2015 06:01 AM
Once you make a component, it should stay in the component menu even if there’s no instance of it in your drawing. Go to the menu bar at the top of the screen and select “Window → Components.” Look for the house icon and click that to view all the components that have been used in your model. You should be able to select them and place them back in your drawing.
View lew's profile
lew
12019 posts in 3725 days
#4 posted 02-03-2015 04:14 PM
Once you make a component, it should stay in the component menu even if there s no instance of it in your drawing. Go to the menu bar at the top of the screen and select “Window → Components.” Look for the house icon and click that to view all the components that have been used in your model. You should be able to select them and place them back in your drawing.
- JAAune
Thanks! That solves some of the same problems I have had!
View TysonK's profile
TysonK
143 posts in 1772 days
#5 posted 02-04-2015 09:57 PM
Sorry if this is known, but just to be sure moving forward, why did you explode your components to make modifications rather than editing them?
Mike’s suggestion to pull your component away for easier editing is a great suggestion.
Another option: under the “View” menu is also an option for “Component Edit”, and this will let you hide other parts of the model while you are editing a component, also useful sometimes. If you find this option helpful, set it to a keyboard shortcut so you can toggle the rest of the model on and off quickly.
-- -- Tyson
View Mark's profile
Mark
#6 posted 02-04-2015 10:51 PM
Thank you for the help gents. JA I followed your suggestion with great success.
Tyson Thanks for your suggestion. I’m still deep in learning mode(with enough knowledge to be dangerous). So the component editing thing was unknown.
-- Mark
View jmartel's profile (online now)
jmartel
7815 posts in 2119 days
#7 posted 02-04-2015 10:56 PM
All you have to do to edit components is to double click on it. It will shade everything else out, you edit it, and then double click somewhere not on the component and it will go back to the normal operating mode.
View Richard's profile
Richard
1916 posts in 2660 days
#8 posted 02-04-2015 11:02 PM
- JAAune
- lew
Helps me out also.
Richard
#9 posted 02-04-2015 11:03 PM
Tyson Thanks for your suggestion. I m still deep in learning mode(with enough knowledge to be dangerous). So the component editing thing was unknown.
- Mark
Mark , you will always be in learning mode unless you are Dead. :)
