Finishing after resawing
Forum topic by Bovine posted 04-18-2009 05:08 AM 1235 views 0 times favorited 4 replies Add to Favorites Watch
View Bovine's profile
Bovine
114 posts in 3291 days
04-18-2009 05:08 AM
Topic tags/keywords: resaw bandsaw
I’m making a jewelry box and have 3/4” stock that I’m going to resaw down to 1/2” on my bandsaw. I’m really new to this, but I’ve made some practice cuts and have found my saw to cut very straight with a 1/2” blade.
My question is, once I’m done, how do you recommend finishing the resawn side? Just sand it down or run it through the planer and take a bit off?
-- Kansas City, KS "Nothing is as permanent as a temporary solution"
35111 posts in 4363 days
#1 posted 04-18-2009 05:10 AM
I usually cut big 1/2” and then thickness plane to final dimension.
View Don K.'s profile
Don K.
1075 posts in 3289 days
#2 posted 04-20-2009 08:05 AM
Same as Karson, Cut just a bit over 1/2 then plane it down.
-- Don S.E. OK
View Sawdust2's profile
Sawdust2
1466 posts in 4050 days
#3 posted 04-20-2009 01:10 PM
That’s what I end up doing.
However, the Woodslicer from Highland Woodworking makes such a smooth cut that if I could be more accurate it would only take sanding.
Bovine
#4 posted 04-20-2009 07:38 PM
Yea, that’s what I ended up doing and I’m really glad I did. That part of the box turned out nice.
