Fixing your slide bracket or upper wheel hinge
Forum topic by klassenl posted 02-03-2015 04:16 AM 2449 views 0 times favorited 2 replies Add to Favorites Watch
View klassenl's profile
klassenl
185 posts in 2656 days
02-03-2015 04:16 AM
Topic tags/keywords: band saw upper slide bracket upper wheel shaft hinge wa14-26 wa14-21
I purchased and old 14” import saw on the cheap, but not cheap enough. Anyway it needs a new upper slide bracket. The guys over at R & D bandsaw stock these parts as well as other stuff and they will ship to the US. The part numbers on mine are wa14-26, and wa14-21. I suggest giving them a call with all of your measurements ready just in case (as opposed to ordering online). Pics for reference.
-- When questioned about using glue on a garbage bin I responded, "Wood working is about good technique and lots of glue........I have the glue part down."
2 replies so far
MrUnix
6709 posts in 2196 days
#1 posted 02-03-2015 04:23 AM
Doesn’t look like there is anything wrong with that bracket?!?
Edit: Oh, wait.. is that a hairline crack where the pivot pin is?
klassenl
#2 posted 02-03-2015 02:11 PM
Yes there is a crack where the pin is. Also on the back where the tension nut is that race is worn.
