Carpet Tape??
Forum topic by Dano posted 476 days ago 256 views 0 times favorited 8 replies Add to Favorites
View Dano's profile
Dano
215 posts in 560 days
476 days ago
I keep seeing the use of double sided carpet tape to temporary attach templates to work pieces for routing etc. I went to the box stores and all I could find was a fiber reinforced thick gummy tape. What I have seen on TV looks to be thinner without any reenforcement, so what is it and where do I get some?
-- Dan in Central Oklahoma, Able to turn good wood into saw dust in the blink of an eye!
2055 posts in 549 days
476 days ago
Dano, I use both types.
The gummy type works well with larger pieces that could come loose and the thin white stuff works with templates and the like.
I don’t see you having a major problem using just the thicker stuff.
I got both at a carpet and tile place.
I try not to shop at the borgs. ( personal preference)
View DAN's profile
DAN
3461 posts in 511 days
476 days ago
I buy mine from walmart. lowes probably has some too.
-- ..... art for lifes sake ... danwalters@lumberjocks.com
View Buckskin's profile
Buckskin
483 posts in 516 days
476 days ago
You might avoid the big box stores and go to specialty carpet and flooring store.
13165 posts in 928 days
476 days ago
The thin stuff is like a piece of plastic with glue on both sides. It is usually the cheapest one you can find. The one with fibers is a better holder. More permanent.
Try five and dime stoors or dollar stores. Thats usually the only kind they carry.
View Hawgnutz's profile
Hawgnutz
505 posts in 604 days
476 days ago
I use the thicker double-sided tape I bought at walmart for pattern routing. the wider gap helps me to space the bearing and the cutting edge. I bought the double-sided tape at Walmart.
I also use some carpet tape that I got at Lowes or Home Depot It is thinner and holds the pattern and project together real well. But. Like Buckskin and other say, you can always find some at a carpert store.
God Bless,
Hawg
-- Saving barnwood from the scrapyards
View Dano's profile
Dano
475 days ago
Thanks folks, Wally world had some of the thinner stuff I was looking for.
Hawgnutz, I already bought some of the thicker tape too, thinking it was thinner. I want to make a couple zero clearance inserts for the table saw and will use it like you suggest to space the original plate and the piece I am working on.
View Drew's profile
Drew
19 posts in 604 days
475 days ago
I found some good carpet tape in the flooring section of Home Despot. It works pretty good but its kind of hard to peel off the backing, A good x-acto blade helps.
-- What would Marc do?
View Thos. Angle's profile
Thos. Angle
3409 posts in 490 days
475 days ago
I use doublesided tape from Woodcraft. I hold templates and use it to set drawer fronts on cabinets. It’s good enough that I hold the wooden jaw guards in my vise jaws with it. I never stop thinking up new ways to use it.
Bookmark And Share This Page
