Respirators
Forum topic by CanadaJeff posted 04-17-2009 03:59 AM 1059 views 0 times favorited 4 replies Add to Favorites Watch
View CanadaJeff's profile
CanadaJeff
207 posts in 3575 days
04-17-2009 03:59 AM
I was wondering what types of protection people use for dust and finishing fumes. I used to use just the standard 99 cent dusk mask, however I always found my glasses fog up. Im thinking a respiratory may be a good choice for both woodworking and finishing. But i have no clue about respirators. Are there different types? Are they good for woodworking or should i mainly use one for finishing?
Any help is appreciated
Cheers
View Francisco Luna's profile
Francisco Luna
943 posts in 3359 days
#1 posted 04-17-2009 04:31 AM
For sanding, sweeping the shop, vacuuming, I use those 3M 8210Plus, work great, I do not use glasses, so I am not sure how they work that way.
-- Nature is my manifestation of God. I go to nature every day for inspiration in the day's work. I follow in building the principles which nature has used in its domain" Frank Lloyd Wright
View marcb's profile
marcb
768 posts in 3639 days
#2 posted 04-17-2009 04:37 AM
The 3M work fine with glasses. I tend to just stick with the painter filters on them, they work fine for dust too.
But if you want to avoid dust, I recommend using a scraper instead of sand paper whenever possible. I still pull the ROS out from time to time, but it really cuts back on the amount of sanding dust I need to create.
View SST's profile
SST
790 posts in 4161 days
#3 posted 04-17-2009 05:01 AM
If you spray solvent based finishes, especially catylized (those with hardeners) you need the kind that protects for that. (I can’t remember the type, but ask at the paint store) It’s not just for the fine particulates, but for the airborne chemical stuff. -SST
-- Accuracy is not in your power tool, it's in you
View SnowyRiver's profile
SnowyRiver
51457 posts in 3446 days
#4 posted 04-17-2009 05:02 AM
I use the 3M type also. They work fine for me. I do wear glasses while working and they dont seem to fog up. I also keep the dust collector and air cleaner running too.
-- Wayne - Plymouth MN
