problem
« back to Scrollsawing forum
Forum topic by supermouse posted 02-02-2015 02:52 PM 902 views 0 times favorited 10 replies Add to Favorites Watch
View supermouse's profile
supermouse
2 posts in 1086 days
02-02-2015 02:52 PM
I have a delta model 40-560 that needs a part that shows it’s obsolete. The part is a link No. 1343636. one bearing is shot . Please help with a solution.
10 replies so far
View Don1's profile
Don1
37 posts in 3626 days
#1 posted 02-02-2015 04:24 PM
The bearing is available from ereplacement parts but it is $30. You may do better with these guys http://www.vxb.com/ballbearings.html
I was able to get the bearings for my Delta saw from them.
Good luck
Don R
-- www.oldcrowscrollwerks.weebly.com
View MrUnix's profile
MrUnix
6202 posts in 2075 days
#2 posted 02-02-2015 05:52 PM
Bearings are off the shelf items.. no need to go to the manufacturer or aftermarket parts supplier and pay tripple what it’s worth. Pull it and get the number from the side and/or measure it (I.D., O.D. and bore) and get it from a bearing supplier such as Accurate Bearing. Replace both while you are at it.
View TheFridge's profile
TheFridge
8675 posts in 1362 days
#3 posted 02-02-2015 05:54 PM
Motion industries is also an option.
View dhazelton's profile
dhazelton
2657 posts in 2173 days
#4 posted 02-02-2015 05:59 PM
I have a motor repair shop local to me and they just measure what I bring them. Out in 5 minutes.
View unbob's profile
unbob
801 posts in 1780 days
#5 posted 02-03-2015 02:17 AM
I had to replace spindle bearings in a shaper, I got a quote from one mentioned above at $1200. Called Accurate Bearing-$425 !!!! Not China, made in Switzerland.
MrUnix
#6 posted 02-03-2015 02:20 AM
Wow.. them were some ‘spensive bearings!
runswithscissors
2605 posts in 1901 days
#7 posted 02-03-2015 07:20 AM
Applied Industrial Technologies is another.
supermouse
#8 posted 02-03-2015 08:43 PM
Thanks to all who responded. I have ordered a new bearing. All I have to do now is figure out how to get the old one out. The entire center is gone and only the outer ring remains pressed in. Any Ideas?
MrUnix
#9 posted 02-03-2015 08:48 PM
Appropriate sized socket and a hammer. Socket and a C-clamp. Wood block and hammer. Hack saw and chisel (be careful not to cut completely through the outer race). Pin punch and a hammer. I could go on, but there are WAY too many ways to remove bearings, even partial ones.
Hope you ordered two.. if one is bad, the other one shouldn’t be too far behind.
dhazelton
#10 posted 02-04-2015 02:01 PM
Sometimes you’re lucky and a piece of PVC pipe is the same diameter. You can take a dull punch and tap it out working your way around (don’t do it hard all on one side).
You say only the outside remains – the outside is the ONLY part of a bearing you should put pressure on. When you insert the new one DO NOT hammer on the inner race. Use a plastic faced mallet or piece of wood or PVC pipe when you install it.
