Can I mix stain into my Poly ???
Forum topic by MNbuzzdust posted 04-16-2009 09:05 PM 1052 views 0 times favorited 6 replies Add to Favorites Watch
View MNbuzzdust's profile
MNbuzzdust
99 posts in 3256 days
04-16-2009 09:05 PM
I am building a six door closet along a slanted ceiling wall. The doors are plywood. I bought some of the plywood a couple weeks ago and the wife picked up the other plywood (2 doors worth) yesterday. I stained them last night and they looked the same. I put my first coat of poly Minwax solvent based on today and now 2 of the doors look a bit lighter. Can I add some stain into my poly before I apply the next coat to darken the 2 doors?? Both are minwax products for solvent based..
Tips appreciated.
View childress's profile
childress
841 posts in 3446 days
#1 posted 04-16-2009 09:15 PM
Yes. I do it. I guess you mean oil based when you say solvent based. I have only done this with oil based poly and stain. Remember that this creates a “tint” in the clear coat. It’s not the same as staining but it does help me out alot when I’m trying to match colors
-- Childress Woodworks
MNbuzzdust
#2 posted 04-16-2009 09:36 PM
Thanks for the reply.
Great any special advice on doing it?? I have basically a 4×8 sheet I need to darken up abit ???
16272 posts in 4123 days
#3 posted 04-16-2009 09:47 PM
My only advice is to do some samples before you do a whole sheet to make sure you are getting the result you want.
View johnpoolesc's profile
johnpoolesc
246 posts in 3265 days
#4 posted 04-16-2009 10:19 PM
i use artist paint in the tubes with oil based poly.. like charlieM said, just test 1st.. and let dry before you decide
-- It's not a sickness, i can stop buying tools anytime.
View Peter Oxley's profile
Peter Oxley
1426 posts in 3779 days
#5 posted 04-16-2009 11:19 PM
Most finishing guys recommend staying under 10% stain when you mix. More than that can lead to adhesion problems. Oh, and the final coat should not be colored.
-- http://www.peteroxley.com/woodworking -- http://north40studios.etsy.com --
MNbuzzdust
#6 posted 04-16-2009 11:52 PM
Sounds like great advice. I ll give it a try. Thanks everyone!
