| Forum topic by Matt | posted 1496 days ago | 3209 views | 2 times favorited | 22 replies | ![]() |
1496 days ago |
Hi guys. I just received my Garret Hack “Hand Plane” book and I’m thoroughly enjoying “the read”. I am particularly intrigued by the section of the book on scrapers. That brings me to this question. I apologize if it’s been hashed and re-hashed here. I did a search and found lots of articles on techniques and some reviews, however, I need a bit more. What brands of scrapers are you using and why? Basically, I’m conducting research so I don’t go out and waste money on something that is cheap or low quality. I don’t mind paying for quality but I really don’t like paying for ‘a name’. Also, what is the minimum amount of equipment required for sharpening/honing scrapers? Thanks in advance, -- Matt - My Websites - http://www.bestinwood.com - Hand Tools :: http://www.workshopgarage.com - Small Shops |
22 replies so far
#1 posted 1496 days ago |
Hard to go wrong here, almost any flat piece of thin metal can be used as a scraper. After using LN, lynx, etc…they are all about the same with the harder steels holding an edge a little longer. You’ll need a file and sandpaper at a minimum along with a burnisher but you could use a a screwdriver. There are some great articles and videos at the fine woodworking site… -- Somewhere, something incredible is waiting to be known. -Carl Sagan |
#2 posted 1496 days ago |
Matt – I buy whatever scrapers Woodcraft has on their shelf, and have been satisfied. I’m sure some of the top-name scrapers hold an edge a little longer or something, but unless you use them all the time, I’m not sure that matters too much. Blake has a video about using and sharpening a scraper, and he just uses a metal file for sharpening. I use sandpaper on a granite block. I guess you could consider either one of those methods pretty close to “minimum”! -- http://www.peteroxley.com -- http://north40studios.etsy.com -- |
#3 posted 1496 days ago |
Matt, Here is a video posted by Todd Clippinger that details his technique for sharpening and using a card scraper. -- Challenges are what make life interesting; overcoming them is what makes life meaningful- Joshua Marine |
#4 posted 1496 days ago |
I would highly recommend this set from Lee Valley: http://www.leevalley.com/wood/page.aspx?c=2&p=61448&cat=1,310 It’s got everything you need and good sharpening instructions. -- Charlie M. "Woodworking - patience = firewood" |
#5 posted 1496 days ago |
There is no other simpler tool like the card scraper with the great work it makes. -- Nature is my manifestation of God. I go to nature every day for inspiration in the day's work. I follow in building the principles which nature has used in its domain" Frank Lloyd Wright |
#6 posted 1495 days ago |
I have a set of cheap scrapers and a swiss made scraper that even came in it’s own little case. I see negligible difference between them. The more expensive scraper takes longer to get an edge on but cuts no better than the cheaper one. I have a round burnisher that came with my chisel set but think a square surface is easier to use. Other than a flat mill file I don’t use anything else. -- Don, Pittsburgh |
#7 posted 1495 days ago |
I use the bacho brand that Rockler carries, works well for me. some people seem to just use a file to get the scraper to working condition – and that will do fine if you’re trying to scrap some paint off some piece… but to get it fine tuned it should really be treated just like every other plane/chisel/blade. and should be properly lapped, and burnished… file → stone/sandpaper → burnisher. for about $5 a scraper, you can’t really go wrong, go experiment. -- ㊍ When in doubt - There is no doubt - Go the safer route. |
#8 posted 1495 days ago |
mine came from woodcraft, under 10 bucks.. but you can not go wronge with anything from lee valley, ever -- It's not a sickness, i can stop buying tools anytime. |
#9 posted 1495 days ago |
I have the Two Cherries scraper and burnisher. |
#10 posted 1494 days ago |
The only difference I’ve found is in the LN ones, especially the thick one, it’s a little harder to use than my Bahco or no name models. Buy one or two (different thicknesses) $5 scrapers and practice with them, once you get it you’ll wonder why you’ve never used them before. Good Luck. -- -JimmyC...Clayton,NC- "Just smile and wave boys, smile and wave" |
#11 posted 1494 days ago |
I have a Lynx set and they work real well. I also work in the steel industry and have gotten my hands on some high carbon steel used to make metal strapping and although it doesn’t seem to hold an edge as long I can cut whatever shapes I need out of it. -- Scott, South Carolina |
#12 posted 1494 days ago |
Hey Matt, I had some very old hand saws that I cut up into hand scrapers I think I got 8 or 10 out of one saw then took a block of wood and cut a grove in it and fit wedges on either side then one wider one on the opposite side to give it a slight bow. I’m not a major tool maker or anything and its not pretty but I have to say it really works like a champ. |
#13 posted 1494 days ago |
I’ve been using card scrapers for more than 40 years. Lately, I’ve been buying them from Lee Valley. Card scrapers – don’t leave home without them. -- 温故知新 |
#14 posted 1494 days ago |
sandhill.. just a fyi, you can change your signature to your complete url, it will work as a link http://woodworkersclassified.net -- It's not a sickness, i can stop buying tools anytime. |
#15 posted 1494 days ago |
I have my URL at the end of my signature or is that not what you are talking about? —Just another day in paradise. I need more tools http://woodworkersclassified.net |
| Forum | Topics |
Woodworking Skill Share
8791 |
Woodturning
220 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1530 |
3547 |
15768 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6157 |
